Finally on all 4 wheels
Hey 744, Man you boys up in Greenville County work fast!!!!
Why don't I buy you a new die, that can be a down payment on the cage you and SC got to bend up for me????
NGABronco Wrote:Why don't I buy you a new die, that can be a down payment on the cage you and SC got to bend up for me????
We got the die welded back together - I don't recommend bending any 250 wall without doing some major re-enforcement to the stock dies. We should have known since it is much thicker than ProTools recommends the die for.
A streeeettchhheeeddd cage huh :xyxthumbs:
Here is some more progress on the Buggy with the Tubular extended Radius arms installed and tacked in that Robert and I are Building.I have to completely remove the arms to weld them in but 1/2 of the frame side is done so it is done for now.BTW .250 wall DOM is way overkill for radius arms and there will only be 3 sets of them as we only got 7 pieces out of a $300.00 + stick of this HEAVY stuff.More to follow on the arms as they are in the test phase.They use Balistic fab mounts with 9/16 bolts and Summit Machine Joints for the flex end and are 37.5 in to the center of the joint for a 8.5 in gain @ the pivot point and if they were any longer and they probally wouldnt work well due to the extended WB as the pivot is now behind the TC.We thought the coils were stock when we started mocking this up but found out there is a small lift in the coils and it threw off the centering of the axle.Problem solved with some of Robert's patented redneck track bars ( AKA Ratchet straps) He He.
Keith looking good as always.:notworthy: Keep up the good work. Plus keep the pictures coming.:toothy12:
Did you get your tires sold? What are you going to run now? I have a set of ProComp 35x15x12.5 MT's if you need them.Cheap.He He
744x4 Wrote:Did you get your tires sold? What are you going to run now? I have a set of ProComp 35x15x12.5 MT's if you need them.Cheap.He He
Keith, PM offshorecorely...he needs some 35's if you still have them.:xyxthumbs:
Sent a PM to him.Thanks for the heads up.
Keith I bought a set of BFG KO the day I sold my tires. Thanks any way.:beer:
Did you go bigger or just a AT.
744x4 Wrote:Did you go bigger or just a AT.
I went with a 33x9.50x15.. So they will fit when I go back uncut look..:xyxthumbs:
  Finally washed the URE mud off my Bronco chuzie 4 1,386 04-13-2009, 01:00 AM
Last Post: trkbilder
  17" Rock Crawler Wheels Series 51 High Pressure 0 1,078 04-27-2008, 02:16 PM
Last Post: High Pressure
  2 new tires and 4 new wheels (new to me anyways) krazybronco 8 2,424 10-22-2007, 12:10 PM
Last Post: krazybronco
