2009 MEB Bronco Shootout
#61
744x4 Wrote:Thats what I thought it was but I popped the cover off the MC and it was only lukewarm to the touch even in the bottom of it.I am going to flush the lines and run some DOT 5 fluid in it and wrap the hard lines and see if it stops this.
Flush them good DOT 5 and DOT 3 don't mix well.
Do you run power brakes? Vacuum or hydroboost?
If dot3 boils in the lines it can cause the wheels to lock up, and only be warm to the touch in the master. Try to rerought the lines or wrap them. Dot 5 may not help with that, and may not react well with the master if its ment for dot 3.
I kind of sounds like the pedal rod is adjusted out too much?
Sounds like it was still a good trip, wish I could have gone.:banghead::crying:
Aaron - he's got the stock vacuum booster.
It's the stock pedal rod and has worked in the past until this heat issue came up. I think it's just time for a flushing, new fluid, and some heat wrap.
They are power Disc brakes using a 77 EB MC and the typical Chevy swap calipers ( 84 Blazer).The Booster is a late 80's Ford LTD booster on a custom Al Bracket that is a exact copy of the EB bracket that worked fine when it was power drum Brakes even with the 77 eb MC. They were touchy when it was 4 wheel drum due to the extra fluid going to them Vs the stock setup.
where are the pics ???
broncomania Wrote:where are the pics ???
back one page... Page 6 I posted some pics of Keith's bronco and our friend's yota truck.
SC74 Wrote:back one page... Page 6 I posted some pics of Keith's bronco and our friend's yota truck.
:beer:
  Tidewater Bronco's Carova Beach Cleanup October 13, 2018 Bronco Biff 0 2,512 08-16-2018, 01:21 PM
  MEB Fawl Crawl Harlan, KY Oct. 12-13, 2012 nhopman 20 7,610 10-15-2012, 01:13 PM
  Gore VA, MEB Roundup Bronco Biff 1 3,443 06-16-2012, 10:25 AM
  MEB At URE - May 19, 2012 nhopman 18 7,244 05-22-2012, 09:57 PM
Last Post: UTFLIWGYA
  MEB Fawl Crawl - October 14-15, 2011 nhopman 1 2,302 09-12-2011, 08:52 PM
  MEB Round Up! June 23-25, 2011 nhopman 1 1,571 04-29-2011, 08:40 AM
Last Post: NGABronco
  MEB Fawl Crawl, Harlan KY October 15-16, *PICS ADDED* nhopman 35 8,225 10-20-2010, 08:17 PM
  MEB Fawl Crawl October 15-16, 2010 nhopman 6 2,579 09-09-2010, 09:43 PM
  MEB and Tidewater Broncos Hitting Hatteras Island Bronco Biff 0 1,369 09-07-2010, 10:58 PM
  MEB Round-Up - Gore, VA 6/25-26 NGABronco 4 3,271 07-07-2010, 07:57 AM
