Don't know what a new processor runs without the core, but if you have any ideas about building the motor or swapping to a 351W you may want to look a the TwEEcer. FordMuscle.com has a lot talk about these. http://www.tweecer.com/index.htm
about the only thing i might do is run shawn's cam in his 306...its listed as an efi cam...so it should be ok-i think.
Mild modifications like camshafts, intakes, heads, and injectors will work fine with the FOMOCO computer. When your start changing displacements it really confuses the factory stuff.
I saw this on craigslist: http://charlotte.craigslist.org/pts/1223334228.html
It is near me if you need someone to do some leg work.
blazinchuck Wrote:i need some help to find the correct computer for my broncos 5.0 conversion...with mass air flow. i also need some air intake tubing and air box.
http://www.carolinarides.com/forum/showt...hp?t=46751
well...some good news. most of the Cage stuff showed up today(ei. frame brackets,axle brackets,new 3.5 coils) however...none of the hardware showed...Dang!
blazinchuck Wrote:well...some good news. most of the Cage stuff showed up today(ei. frame brackets,axle brackets,new 3.5 coils) however...none of the hardware showed...Dang!
i know the feeling. my stuff came that way from wh. mine had bolts but the wrong length Confusedcratchhe:.
I thought you had to get that engine and tranny installed first before the suspensios and axles.
have fun with the pics boys and girls...i still have a bronco to build!:xyxthumbs:
a few more, gonna try to get the trans/tcase installed today. i rolled it out of the shop yesterday to pressure wash the frame and engine bay. cant tell ya how that made me feel to see it in the yard and not the shopConfusedmokin::toothy12:
ordered this today...
RJM EFI harness
equalizer bracket for the 5.0 to use mech. clutch
trac bar riser,adj trac bar,rear shock mounts
still need more stuff tho...TBC...:popc1:
Hell yeah!!! Lookin good, bro!
Love the wheel well patch!
  Bertolini's '71 build blazinchuck 4 1,664 09-13-2015, 08:49 PM
Users browsing this thread: 110 Guest(s)
