UGH!!!!!!! i need a D60 hub tool for tightening the spindle nuts.....
sounds like your driving same boat i was in..think ur just about there and pow gotta go get something else.. just use some duct tape that chit will hold a race car together..lmao j/k great thread hope to use some of the info for later projects!!
got a visit from ncsubronc today...he showed up in his 1/2 cab(sweet bronco)! i ordered some QA1 heim joints to replace the worn out joints on the tie rod, hope they show up Monday or Tuesday. so after installing the pass side warn hub, we took the bronco around the hood for a drive. pulled into the power lines and crossing a ditch when alot of smoke...THEN FIRE! the whole driver side when up in flames...luckily the new fire extinguisher was ready and easily at reach. got the fire out, backed out of the ditch, and replaced the hose that blew off. put a quart of PS fluid in it to get it back to the garage. glad it happened today and not next week at URE. need to get a compression fitting to make this hose more fool proof. thats twice it came off and caught fire. thanks for the help Jeremy!
that reminds me i have to go pick up a couple extinguishers to put in trail rig. def good that you found it early.
need some input hydro guys...i want to install mine, but its looking to cramped on the axle with the ram mounted on the WH track bar riser and the ram mounted to the tie rod...comes close to the diff cover when turned full left(DRIVER SIDE)
anyone run them on the drag link? anyone make a mount from the bronco frame/cross member to the drag link?
I take full responsibility for that PS line Chuck since I took you a little too literally when you said you wanted it "tight" when I installed it. Sad
dont worry bout it, gonna get a new fitting on the box that will fix this 100%.
dang chuzie you must have used that german torque spec on it....goodntite! lmao
after some prep work yesterday with Chuzie's help...I finished up the hydro assist. Everything seems to be working good, hope to drive it around some tomorrow. here are a few pics.
thanks Chuzie:xyxthumbs:
That's something we've got to iron out on the giant pumpkin. I don't think there is enough room to do it like yours so might end up going off of the diff cover. Looks good Chuck!
  Bertolini's '71 build blazinchuck 4 2,074 09-13-2015, 08:49 PM
