tube doors for full size bronco pre-made and ready for you!!!
Okay got the top cut up and working on that. Have made ONE tube door drivers side. I dont have any idea how to load the pictures to post them. if you want to see what they look like then email me @ erickruger@cox.net What they are made from will suprise the Shat out of you and it provides the release handle and is made out of 1 1/2 steel tubing. So far cost is at 100 for the tube doors +30 parts and peices and 3 hours total.
I figure total of 150 max, and 12 hours.Confusedcratchhe:
So email me!!!
create a account with photobucket, then upload them there, them copy/pate them here....
or upgrade to full membership, and upload them right from your computer to this site.
cant wait to see the doors...good job!
Are they for all fullsize years?
Lets see those pics
:popc1::popc1::popc1:
he sent this email to me, so im posting what he said
Quote:And with just a small amount of modifacation they turn into this. they look better than any i have seen made. the two big things i have to work out is at the front there is is stil about a 1/2 degree bend but i will straighten in out in a press and where and who i am going to attach the door latch. they come with a nifty cable and tee pull handle that can be used to attach to the door latch. I bought 1 peice of u chanel at home depot and that is what they are welded to. I drilled and bolted the chanel to the hinges and welded the bolt heads to the chanel so they are permanent. this is just how i did it. you can work out your own attachment method. Gotta admit it looks made for the opening.
heres the pics he sent me
And the concenss is how do they look!!
i might just have to go to a pick and pull! but i would want mine removable
I would be real interested in a set of these if they were removable!
Anthony,
What i did get spare tire racks off of a 2000? pathfinder and cut off all the crap. Welded them to a steel plate that i drilled and welded bolts to so i can bolt and unbolt them so i can put the original doors back on. any style tire rack will do just look at em and imagine them in the door opening. If you dont weld then take the tire racks to a welding shop and they can cut and weld em up. The only thing you have to work out is the latch. Right now i use a motorcycle strap cuase i have not worked out how i want the latch to work, i want it to stay factory using the original door striker post. Feel free to ask more questions.
  Latest Bronco Driver Cameo Bronco Biff 9 3,072 05-10-2017, 11:55 PM
  what have you wrenched on your bronco(s) today? firefighter2134 2,039 276,109 03-27-2017, 11:17 AM
  Bronco new year resolutions wepuckett 12 2,735 01-03-2016, 11:52 AM
  Check this bronco out snipes243 5 3,379 12-29-2015, 08:58 PM
  Charlotte Motor Speedway looking for a nice 1980-1996 Full Size BicksBroncs 0 1,360 09-10-2015, 05:18 PM
Last Post: BicksBroncs
  The Bronco made the news today snipes243 8 2,075 08-24-2015, 12:45 PM
