short or bad ground?
so i think that i have traced the short to the steering column. i will pull steering wheel and turn signal switch out along with wiring and see if i can find the culprit. but for now i cant get fuse to blow again..go figure
i think that i found the culprit of my problem! bad turn signal switch. i have lost turn signals but not blowing fuses anymore. so hopefully i wont be running in circles...
Those turn signal switches can cause a lot of problems..Wink
Its a flaming river tilt column.
  Shocks: Good or Bad? Crawdad 9 4,399 01-14-2011, 12:18 PM
Last Post: Timstrk
  Bronco Bad news cuz1 17 2,678 08-09-2009, 06:36 PM
