the 77's upgrades
thats very similar...i wonder if they started cutting the angle on the leading edge of that bracket to clear sticks?
got a few things done this past week...
1) recalibrated my fuel sender unit(used to barely go past 3/4@ full, and go way below E and still have over 5gal in tank) today it went just past full and should be just below E for empty.
2) bought and installed new WH's 3.5 11 leaf springs(they came with extreme 9/16th ubolt kit and shocks)
3) installed a storage box from FBG(right behind the rear seat)
4)replaced the front driver side caliper
5)installed a new CB antenna with quick disconnect for parking in garage
might try to install a "line lock" soon
How much do you want for your old springs?
dixieboyz13 Wrote:How much do you want for your old springs?
sorry Bard, a buddy of mine locally is buying them
Bard :hysterical:
chuzie Wrote:Bard :hysterical:
:bangheadConfusedorry...Brad!
:thefinger: chussyConfusedmokin:
:thefinger::thefinger::thefinger:
got me a driver side 79 F150 inner/outer axle shaft. replaced the u-joint with a new spicer today. ill try to get it installed tomorrow. this is a simple upgrade to the larger u-joint(760 vs. 260)
planning to rip the front suspension out this weekend.
i keep taking measurements and nothing seems right. 1/16th here,1/8th there, and even 1/2" in another area. so im gonna try to straighten some things out. hoping to solve the bronco lean too
thanks to bart...i got the eaton e-locker for the d44 today!
got a painless 6 rocker style switch panel from shawn.gonna be some nice upgrades very soon. installing 4.56 gears, LED rock lights, on board air/tank
Users browsing this thread: 52 Guest(s)
