Extended Radius Arms
Cam, no need to drop the arms at the frame...that was only done to compensate for the caster and short(stock) arms(old skool). i dont recommend dropped arm mounts...keep it as close to the frame...better for break-over angles.
Ok, do I need to get new C bushings because mine are the ones relocated to 7 degrees. also right now I am obviously running the stock arms and my coils have a bow look to them, the Bronco rides like its on glass on the Hwy. Would this have any effect on steering?
you might need less caster than 7 degree, most long arms have 4 degree caster built in them.
I am ordering the material tomorrow and will post pics! Thanks for all of the Ideas
OK, I got the arms finished up and went a totally different route than the DOM. I found a set of wishbone arms from a 41' ford sedan...I know it sounds like some backyard rigging but it actually turned out perfect. The arms from the 41' have a tapered shape and actually measure .210 wall thickness (pretty close to 1/4). I took the same approach as everyone recommended to cut the originals and notch the new ones. Turned out great and didn't spend a dime!
Very nice... extra creative points too! What end are you going to use on the frame end?
I have it set up for a 3/4 rod end. I welded a threaded piece of 1 1/4 DOM in the ends of the arms, I thought it would give me more adjustment on the length. Can't wait to install them!
Is that a 3/4" bolt holding the place of your rod end? Rod ends are fine thread. Hope it works out.
[Image: 2rwp56f.png]
Yeah, i try to put a bolt in place while fabing things up with a thread involved..kinda holds everything in place and keeps splatter out. And it is a 3/4 16 fine thread even though it looks bigger in the pictures, I am kinda nervous about the 3/4 but I think it should be fine.
Good plan and good re-use of available material. I do stuff like that.
  The 5/16" square hole in 76-77 radius arms Crawdad 3 3,148 01-14-2015, 12:38 AM
  Radius arm bushing cause of grinding/vibration sound? 1st Bronco 7 1,954 09-13-2013, 09:47 AM
  RADIUS ARM BUSHINGS chulo2004 4 3,359 08-21-2009, 11:12 PM
Last Post: chulo2004
  I need to know the Radius Arm width. 2000F150SAS 0 900 06-17-2009, 10:00 AM
Last Post: 2000F150SAS
