Irmo73's Build
#41
Those threads look shot.
Death wobble is (usually) caused by worn bushings in the track bar or related hardware. Right now I am working on a 74. The lower bolt (the one with the 1-1/8" castle nut on it) was loose. From the factory it is welded to the axle housing. That weld had broken and the bolt had a lot of movement to it. I discovered it while taking the track bar off to replace bushings in it. Check the upper mount as well for any movement or broken welds.
broncosbybart Wrote:Those threads look shot.
thanks!!
definitely going to check the track bar, bushings, and bolts
pretty sure the track bar and bushings are fairly new though
funny how this happened after new front discs and a little more air in the tires
looks like the radius arms are shot
i guess im lucky that we were already looking at the front end for the regearing
Irmo73 Wrote:thanks!!
got the WHs radius arms coming this week
they seem perfect for a mainly street rig
are they extended? i had a set of their older boxed arm/extended style...they were awesome on road and off. i recommend their "degree frame mount arm bushings" is ya plan to offroad at all...they allow the front to work great and droop
blazinchuck Wrote:are they extended? i had a set of their older boxed arm/extended style...they were awesome on road and off. i recommend their "degree frame mount arm bushings" is ya plan to offroad at all...they allow the front to work great and droop
theyre modified from stock to fit lifted vehicles and apparently great all-purpose arms
but i dont think that makes them extended, does it?
im not really planning on offroading much, so mainly street setup
got a link to the arms?
blazinchuck Wrote:got a link to the arms?
http://www.wildhorses4x4.com/product/Ext...adius_Arms
whatdya think?
the info on the site says theyre 12" longer than stock
so that makes them extended, right?
yep...longer. which is a great thing IMO. you may want to call them and ask what lift bushing you should run on those arms. im sure they have some caster built into them(most arms do) those will look sweet!!! are you sending your arms back to them for the core? ya gonna have the same guy install them or do this work yourself?
I have a set of arms you can send in place of yours. Just give me yours when you have the new ones installed. That way you wont loose any road time. These came off my 73, nothing wrong w/ them. I was thinking of powndercoating them, just haven't done it yet.
  Broncitis Rat Rod build thread. Broncitis 121 29,233 04-01-2016, 10:53 PM
  Lil Red Riding Hood Build Broncitis 11 6,761 03-04-2016, 12:14 AM
  92 Fullsize Build - Scotts Bronco nitro 44 8,636 01-12-2012, 08:45 AM
Last Post: nitro
  70 early bronco (mild build up) broncomania 8 1,938 12-09-2008, 11:56 PM
  My new horse: 1991 Bronco trail build. manny 5 4,727 09-11-2008, 12:54 PM
Last Post: manny
  my bronco build pics broncomania 83 16,106 09-07-2008, 10:59 PM
Last Post: Mill Knob
  Rotisserie Build Bighorn 3 1,152 08-26-2008, 04:23 PM
  Engine build advice cuz1 6 1,550 06-27-2008, 05:35 PM
  got any 1st build pics? blazinchuck 5 1,488 06-18-2008, 06:45 PM
Last Post: DUCKWORTH71/76
  JP's 1st build pics johnpaulgolf 2 1,652 06-18-2008, 07:56 AM
Users browsing this thread: 26 Guest(s)
