Irmo73's Build
#71
If ur a mall crawler like me ur PS pump will be fine with 33s. I did the Sagi PS change only bc I had 37s. Now that I have skinny 33s the steering feels like the old PS pump, nice and smooth.
I am now going to have 35s instead of 33s
but the BFG ATs 35s are actually 4 pounds lighter each then the Goodyear MTs 33s i had
what is the actual name of the stock power steering pump? is it just a ford pump??
Irmo73 Wrote:I am now going to have 35s instead of 33s
Yep, its FORD. Rebuilts are hit & miss. Mine kept squealing/ whistling to hi heaven when I gave it gas. It finally gave out so I went Sagi due to the 37s I had. Going Sagi is a very good addition to your Hydroboost set-up. Lots are doing it on Classic. But I think you will need a dual return Sagi pump since you have HB. But then again how is ur HB working w/o a Sagi????? None-the-less the Sagi PS is a good add-on.
Crawdad Wrote:Yep, its FORD. Rebuilts are hit & miss. Mine kept squealing/ whistling to hi heaven when I gave it gas. It finally gave out so I went Sagi due to the 37s I had. Going Sagi is a very good addition to your Hydroboost set-up. Lots are doing it on Classic. But I think you will need a dual return Sagi pump since you have HB. But then again how is ur HB working w/o a Sagi????? None-the-less the Sagi PS is a good add-on.
havent had a problem yet with the stock pump but if i do, probably just get a saginaw
wonder if i can pull one from somewhere around here
there any good junkyards closeby?
Irmo73 Wrote:havent had a problem yet with the stock pump but if i do, probably just get a saginaw
I've got one that I bought from a guy on Classic. It's used but it looks like its in great shape with dual return and the mounting bracket (with the notch cut out).
BucknEB Wrote:I've got one that I bought from a guy on Classic. It's used but it looks like its in great shape with dual return and the mounting bracket (with the notch cut out).
thanks!
i may need it but lets see what happens first when i power her up
PM me if you want it. I can post a picture later.
I'm going to swap in the 5.0 soon and I'm doing the explorer Serpentine set up with all the explorer accessories , so I won't be using it. It needs a good home.:xyxthumbs:
Irmo73 Wrote:thanks!
Cool.Confusedmokin:
I got my Sagi from a guy in GA. He never installed it. He said he bought it from Scrapman who is a vendor on Classic. Doug should have all the parts you need on a 302. A 351W like mine needed an extra bracket to work. I have a pretty good write up on this website.
My old soft top is up for donation if anyone wants to pick it up
It's admittedly not in great shape - nothing specific just worn out
It's the old kayline type with buttons and roll up windows
  Broncitis Rat Rod build thread. Broncitis 121 34,069 04-01-2016, 10:53 PM
  Lil Red Riding Hood Build Broncitis 11 7,382 03-04-2016, 12:14 AM
  92 Fullsize Build - Scotts Bronco nitro 44 10,438 01-12-2012, 08:45 AM
Last Post: nitro
  70 early bronco (mild build up) broncomania 8 2,440 12-09-2008, 11:56 PM
  My new horse: 1991 Bronco trail build. manny 5 5,093 09-11-2008, 12:54 PM
Last Post: manny
  my bronco build pics broncomania 83 19,189 09-07-2008, 10:59 PM
Last Post: Mill Knob
  Rotisserie Build Bighorn 3 1,399 08-26-2008, 04:23 PM
  Engine build advice cuz1 6 1,872 06-27-2008, 05:35 PM
  got any 1st build pics? blazinchuck 5 1,793 06-18-2008, 06:45 PM
Last Post: DUCKWORTH71/76
  JP's 1st build pics johnpaulgolf 2 1,843 06-18-2008, 07:56 AM
Users browsing this thread:
