* Carolina Broncos 7th Annual NOV RUN @ URE *
#91
chuzie Wrote:Clay, her name is Fistina!
Chuck, something got lost in translation there. Try again
I think Chuck finally got my post in his build thread-
[sounds like you've been busy. your EB sounds nicer every post!
how hard was that dakota digital setup to install? what tools are required for that? might have to bring some extra tools and a flashlight with me to the URE run Big Grin ]
I knew that was coming. Damn you are predictable!
Anyway, I have always had gas in the tank, just a pickup problem. Hope the massive accumulator I installed will prevent that problem this year.
Oh, and I have a new battery so no wimpy winch on kodak
Well, I mean if you run out of gas every run, you're going to hear about it all the time, right? I'll beat that dead horse. (pun intended)
Now the girlfriend thing, I'll leave those comments to everyone else Big Grin
Hey man, I reap what I sow! Bring it on.
Just under 2 weeks away - So, who's still wrenching on their junk to get it ready? I got the axle shaft replaced that I broke in Harlan and changed my hubs to original Ford hubs, other than checking fluids I'm ready to roll.
Nick
Well my junk is in Charleston collecting tree sap and I am in Tampa untill next Sunday. As usual, I will be down to the wire. Could go as is but I would like to do a few things...
Repair rear shock issue
Mount ram assist
Make bumper somewhat usable
Install rock lights
Install trans temp sender
Install clutch lockup switch
I work all that week leading up to URE so I hope to have enough time in the evening to button this stuff up.
Working on a winch bumper.......Hmm, need to order a bettery tray and get some cable.....Right now I'm runnig out to gas up the Truck and get some generator petrol incase Sandy the Frankenstorm slaps us around a little bit!! Just picked up some oil after the boys ball game for an oil chnge in the 4door....need to get the recalled tires replaced also.
Yes just starting to put new Dana 60 in hope to have it done by then. With my new 42 irocks on it.
My rig is waiting on me to use it. Guess I should at least check fluid levels and tire pressures...
A little more than a week away!! When are you planning to show up? I'm thinking early Friday afternoon (2 or so).
  16th Annual CB4x4 November Run snipes243 1 5,694 07-06-2022, 06:52 PM
  15th Annual NovRun AKA 2020 RonaRun Bronco Biff 0 5,767 11-09-2020, 01:05 PM
  10th Annual NovRun@URE '15 **The Big One Zero**TEN** chuzie 325 114,270 10-25-2020, 01:16 PM
  14th Annual NOVRN@URE!! blazinchuck 15 10,708 11-10-2019, 08:37 PM
  2018 Annual NovRun @ Uwharrie coming up November 3rd!!! The traditon lives on!! Bronco Biff 5 5,881 11-05-2018, 01:25 PM
  12th Annual NovRun@URE '17 - TWELVE!!!! chuzie 18 10,926 11-06-2017, 11:14 PM
Last Post: godevil
  December uwharrie run snipes243 1 3,224 12-11-2016, 05:47 PM
  2016 Annual NovRun @ Uwharrie coming up November 11th!!! Bronco Biff 148 36,571 11-20-2016, 10:04 PM
  Gulches day run - Sat March 28th chuzie 16 7,108 04-07-2015, 03:19 AM
  9th Annual NOVRUN@URE '14 chuzie 172 35,779 12-31-2014, 12:17 AM
