My little mule, Pe'pe
I really need to drop by and check it all out! Looks like you are making some progress.
I decided to wait untill I had the frame under the tub before I installed the aluminum pannels. I didnt want to put a screw where I couldent get it out because the frame is in the way. So I put it back on the frame with new bushings. Its hard to belive but I did this all by my self with nothing but an engine hoist. Need to measure and cut some aluminum next and then I can start stripping the top side. More to come!
Since I'm avoiding cutting the aluminum sheet right now (its loud), even with my ear muffs on so I worked on opening up the rad support. I origanly was going to make one from 1" square stock, but that was the old tub that didnt have any inner fenders or rad support. Since this one has one I opened it up, may cut some more tomorrow. I will need to notch the old battery mount ribs. They are too tall to fit my trans coolers and fans. Still undecided if I will use the fans I have (the ones in the pic) or go back to the 10" pullers I used originaly. The ones in the pic are pushers and are 3/4" thicker which makes fitting them in harder. The pro to these is I have a bunch (8 to be exact) and they were free.
I will need to fab all new mounts for the coolers and the radiator since this was a 6cyl tub. Of course once all the coolers, radiator and fans are mounted I may need to fill in some gaps between things to maximize air flow.
After a few months of not working on my own stuff I am back at it again. Spent some time rebuilding a Tcase for a customer and a friend has me working on a chevy truck for his wife (been sitting for 10 years).
Now I am back to the tear down of Pe'pe, If there were any question of how bad it needs a new body and frame. Look at the pic of the inner rear fender. The only thing holding it on is the cage.
The one thing I have done lately is score some more toys for my collection.
More to come!
Obsessed much? Geez bro. I though i has an addiction, but you take things to a whole new level!
Glad you are back at it with pepe. I hope you will set a goal to be ready for URE next year. Sure would be nice to have someone to caravan with!
Sent from my SAMSUNG-S3 using Tapatalk 2 on CyanogenMod
Nothing a little bonds can't fix
Well after a very long time I'm starting the tear down of Pe'pe. Some of the parts on this truck I put on over 18 years ago.
The rust has realy taken its toll on the tub, the rockers are nearly gone. Cutting out the wiring is like trimming a bush, just cut and pull. It was first built with some parts only set up as a test to see if I liked them, but there still that way. All that will change now that I like how it all works. The gas tank and rear axle are next, Just got a truss for the 9".
:beer:
If you cut out all the wires, where are the rats going to live? I think you and I are in the same boat. I am to the point where I have installed a bunch of test circuits and stuff but never made them permanent and proper. The result is a mess just like yours. Feel free to drive down and fix my wiring mess too!
BTW- I leave for URE in 9 days. Last chance to change your mind!!!!!!
Anxious to see what all you do to her!
Your progress report is great. The pictures make it look like your project is in your basement, I realize your not, but when I was a kid on Lake Erie, a neighbor built a sailboat in his basement and had to disassemble part of it to get it out. Please keep us updated.
VIN# makes it a 1985, the engine block# is an 1989, and the front end is from a 1987. I call it Broncenstein. [Image: bronco.gif]
Users browsing this thread: 100 Guest(s)
