10-20-2015, 01:58 PM
Yeah I thought it was pretty cool. One of thes better 4 doors I have seen. Price seems high to me. For half of that you could get a double cab brute with a v8 swap. Still cool thou
10-20-2015, 02:04 PM
From what I understand they build a custom frame and the works they had a different trailer with a huge tent at SC last year they will probably be at SC this next year
10-23-2015, 10:29 PM
Installed my new hydraulic steering cylinder. It is nice to have it back. Without it, things we a bit sensitive.
Trimmed a bit out of my inner wheel wells in the rear. I found a small portion impacting the tires when fully stuffed. Got the Bronco washed. Looking great. I think I am going to order some custom battery holders for my Odysseys. The cheap parts house holders just aren't cutting it. Had a terminal come off again tonight.
10-24-2015, 05:02 PM
Well my tires either need balancing or the slop in my rear driveshaft splines is causing a vibe. Pulled all the weights from my wheels and prepped the surfaced for adhesive weights. Unfortunately the only place that does road force balancing closed before I could get there so I will have to wait until Monday. If the vibe is still there after I balance the tires, I will be ordering a driveshaft from Tom Woods. $$$ UGH!
10-24-2015, 06:06 PM
Carolina driveline or Oliver drive shaft better shaft and cheaper price
10-24-2015, 10:10 PM
I'm happy with the work that Dave at Oliver's did for me. DO NOT use driveshafter on classic.
10-24-2015, 10:14 PM
I'm not gonna ask you to bash a vendor now, but please remember to fill me in at ure.
10-25-2015, 06:00 PM
I actually looked at it today and feeling guilty about not doing anything to it lately I went ahead and chased down which cylinder was causing a skip.The #3 cylinder plug was wet so I changed it out and the skip is gone. Purrin like a kitten. Then I put a new fuel filter on it and replaced the heater hoses. Drove it around the horseshoe rd climbed a lil clay bank and back. Ready for URE if nothing else goes wrong.
Oh Yes Chuck I have got the 7th deer of the year now 4 in the last week. Freezer is in great shape. Jerky Meat is marinating in the fridge.
10-26-2015, 08:03 PM
Had my tires balanced today. Their fancy road force balancer could not handle my 12.50 widths so I had to settle for a static only balance. We got all of them down to 0.00 imbalance, including the spare I all but destroyed at Tellico. After the balancing I had them throw my Dynabeads in each tire for long term maintenance.
She is definitely riding better but I still have a vibe and I can't believe it is a dynamic imbalance. Tomorrow I will place the rear axle on stands and see if I can observe the rear driveshaft vibrating. If so, gotta make some calls to a few driveshaft manufacturers.
10-26-2015, 11:20 PM
Garage is cleaned out and the truck is in ready to install some shocks tomorrow. And my shock bushings showed up early
![]() ![]() Sent from my iPhone using Tapatalk
Bucking Bronco | ParadisePWoffrD | 0 | 787 |
Check this bronco out | snipes243 | 5 | 3,249 |
Bronco Christmas | snipes243 | 23 | 4,097 |
