mini buildup
Grinder and lot of work haha
Finally they are in just need to charge the one and attach the reservoirs, and ready for the November run.[Image: e7a2dbc2149508fa9a7ba88a70d9744f.jpg]
Just button everything up tomorrow and nut and bolt the bronco and I'm ready.
Bout dayum time!
Well my new and improved steering box showed up. It looks pretty cool hope it works better. [Image: c915933d0c23ec209ff76fd16159f8e5.jpg][Image: 4b0b35f3193ef81edec1d9204c1403dd.jpg]
So I have to get out all the old red ps fluid out of the pump so my new box is covered under warranty. I was thinking about drain the pump filling it up with new fluid. Do this a few times to get the old out. Any other ideas?
I think that would work
Sent from my HTC6535LVW using Tapatalk
It will go fast so watch it closely or you will run dry.
chuzie Wrote:It will go fast so watch it closely or you will run dry.
Not planning to do it while it was running
Pu$$y
Well As I was getting ready to start changing my Ps box out I discovered my Arb HD line had tore not sure how that happend. Then while I was removing it, I noticed that the motor mounts were broke. Lucky I have a set of wild horse extreme mounts that I have been trying to put on. So last night I managed to get the drivers side in and bolt up minus the bottom stud. The pass anger side was another story I got the mount in but all three holes are lining up. I think the motor is in the wrong position. Have to look at it tonight.
Fun project tonight got the lucky 13 led headlights in tonight [Image: a7f00147c8c43bf1c0d206291e4b01dc.jpg][Image: 2142d6127e7a0b052ea05e4deb4a63e6.jpg]
Users browsing this thread: 65 Guest(s)
