ParadisePWoffrd's EB
damn, looks rough
Haven't had much chance to repair.
Found the culprit to the body damage. Apparently the front suspension/axles it pushed to the pass side some, allowing the tire to get into everything.
Working to rebuild the front suspension.
Started by removing the bent truss and replacing/upgrading it and bracing the inner Cs.[Image: 2f8e8181fc0fe9de70a4a5909103981a.jpg][Image: be22c2edb41b9461867f9793ba1244b9.jpg]
Sent from my SM-G955U using Tapatalk
Question for those still around. How valuable is a factory frame?
I am looking at trying to get more travel, which means the frame rails are in the way. Trying to determine if I should cut the rails or build a whole new frame.
ParadisePWoffrD Wrote:Question for those still around. How valuable is a factory frame?
No one is around anymore. We have a group on Facebook but it's dead too. I've seen people sell frames for under 300.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Generally worth more with a title
Heyyyyyy!!!! People!!!
I sold my last frame for $100, If your going to cut the original its no big deal. There is a vin stamped on the top of the frame that matches your title.
You can also get new frames. I say cut and modify!!!
broncomatt Wrote:I sold my last frame for $100, If your going to cut the original its no big deal. There is a vin stamped on the top of the frame that matches your title.
Good deal. It's not worth the extra work to save $100 worth of frame. Esp since the factory susp mounts are gone anyway.
