A few questions
so Carl you going to be driving 2 different classes then?
snipes243 Wrote:so Carl you going to be driving 2 different classes then?
I am not sure yet. I have a good buddy who I may let drive and I will put Matt Miner in the passenger seat if he wants to ride. Still have a lot of work to do to the bronco before the race. Roll cag, seats, propane, tires!!!
so does welded count?:finger:
blazinchuck Wrote:so does welded count?:finger:
I don't think so. Nor does a spool or an aussie locker, which I have. So what your'e saying is quit being a cheater and move up a class. I think I agree.
What year are you? Drum or disk in front?
I have searched high and low. Have you tried calling the parts counter at a ford dealership?
It is a 76 with disc brakes.
Funny enough I can get every dimension known to man for those axles and options for those years and nothing gives me info on lockers in the front.
I do not think they will let me in the stock class anyway because they are scared I will kick some ass. So, I will go to the next class up.
thanks for the help
cw
Carl, its good and its bad. Yes, the rear axle could be ordered with a factory posi. It would only be listed on the finish sheet(usualy behind the back cover on the pass front seat) and on the axle tag. The door tag only listed a code for weight rating if its there at all. Here is where things get funny. If a dealer took an order for one with rear posi, but he had one on the lot with everything but a posi. Then it may have been put in at the dealer.
It is also listed in some of the books I have as being an option for a front posi. But again many dealers put them in too. I think even if the truck came with posi's it would be moved up too the same class as the Rubicon.
  Got some EB questions for you guys. dirty_sohc 2 2,262 10-19-2012, 10:31 PM
Last Post: dirty_sohc
  Hub/ Rotor questions Crawdad 2 1,838 01-31-2012, 09:46 PM
  Stock questions Olredneck 3 1,272 08-18-2009, 09:32 PM
  Caster Questions SC74 0 2,008 11-16-2008, 04:54 PM
  roll cage questions johnpaulgolf 21 5,456 12-09-2007, 06:37 AM
