repair work
As most of you know I stuck my eb, and as a result I broke the track bar mount at the frame. Unfortunetly the list of problems did not end there.
As a bi product of playing in the mud I decide to pressure wash all the mud off. A design flaw I had not thought of allowed water to flow directly into the vavle cover. Fortunetly I only ran it long enough to drive it into my shop.
The throttle cable also became bound up, combination of poor istilation and mud clogging the sheath.
I have put my spare throttle cable on, and I will probably upgrade to a Locar unit soon. I have drained the oil, blown out the oil cooler hoses, cooler and flushed them with brake clean and some fresh oil. I will run it with some fresh oil and change again. Just frustrated with my self for not forseing this.
I am going to use this as an opertunity to upgrade my ventilation system.
Inspired by looking a Dakar trucks for the last few weeks I am building an airbox for crank case, tranny, front diff, and eventuly the T-case.
The plastic box in the photo will have a plate bolted down with all the fittings on it. A stock air filter to keep it clean.
Bouncing my way threw the hole has realy reminded my how bad the body rot is on this tub. I will have to do some further inspection to my rear quarter pannel. I realy need to get started on my other tub.:popc1:
I found some more pics of my stuck, included are some pics of the diff cover I made. 1/2"square stock in between the two covers.
[Image: ebproject004.jpg]
[Image: ebproject003.jpg]
[Image: ebproject002.jpg]
[Image: ebproject001.jpg]
[Image: cap017.jpg]
[Image: cap016.jpg]
[Image: cap015.jpg]
[Image: cap014.jpg]
[Image: cap013.jpg]
[Image: cap011.jpg]
[Image: cap008.jpg]
[Image: cap002.jpg]
I like the central airbox idea. Let me know how it works out I may copy it at some point.
chuzie Wrote:I like the central airbox idea. Let me know how it works out I may copy it at some point.
I've also thought of something along the same lines. I've looked at some store bought stuff but all too expensive - I like the homeade creativity and may still your ideas when you're done :beer:
I like your take on the diff guard. My looked like a golf ballConfusedcratchhe: after a few trips to URE.
Ok, here is my vent box. It started life as a stock air cleaner box for a dodge stealth. Liz's has a K&n so it will no longer need it.
I made a plate out of some scrap aluminum. Got the three fittings I would need. One is for the tranny case, one for the crank case ventilation, the other is the front diff(blue anodized).
The one for the crank case is the larger(1/2"), it uses a 3/4 npt, I used a 3/4 electrical nut(for an outlet box, ect) to hold it on. If they had not been out of them for the smaller (3/8") I would have used one there. Insted I taped the hole and threded it in with some sealer on the threads of all.
It will use a stock air filter, mount the plate where the mass airflow senser would have mounted. I will install this on the pass side inner fender. It will aslo allow me to remove a coolent resavore for a better one.
[Image: P1010023.jpg]
[Image: P1010021.jpg]
sorry I loaded them backwards. I will also mention that the opening will face the fire wall, and have some screen(litteretly house screen) covering the opening.
My rear diff vents inside the rear quarter, the t-case has a stock vent.
I'll take more pics once I mount it.
sweet!
I like the way you think! Good invention.
Spent some time this weekend finishing up the airbox install. When the new body is put on it will get diffrent mounts, but these are plenty strong.
I feel much better diving into deep water, mud, silt with this system.
I also included what else I've been working on. Liz's stealth motor, nice engine. The tranny was also overhauled.
[Image: hkutid7t.jpg]
[Image: hjuyti7t.jpg]
[Image: guiu7876.jpg]
[Image: bvhmjkugi8.jpg]
[Image: bvjnyu.jpg]
[Image: ghjytui8768.jpg]
will it still be able to breathe when the foam is soaked in mud?
  how much work goinpostal 2 2,355 02-15-2011, 10:45 AM
  finally did some work snipes243 8 4,581 04-21-2008, 11:38 PM
  who likes to work on carbs!!! offshorecorley 3 2,931 10-20-2007, 10:54 AM
