my bronco...
well here's a couple of shots of my bronco.
http://cid-8c4a8146d7fc22f4.skydrive.liv...&ct=photos
and here's a few of the shop. Got power monday!!!
hope they come thru. I'll update the build as soon as i'm finished with the shop so i can begin..
Shon
I think my rust is rusting...
pics work. thanks for sharing. how big is the shop ? whats the plans for the bronco ?
20 x 24 . 10 ft. walls.
first plan is to get it inside and see what i have. PO has a bunch of poly mounts, disc brake parts , i have an extra column and a couple of dashes.
i worked in the rain and mud years ago. so i'm waiting til i'm done with the building to get started. good running little 6 , absolutely no brakes , drum/drum , 3spd on 31's . I have everything to rebuild the drums .
But i fire it up and putt around in lowrange from time to time. a few drops in the carb and she fires right up. swapped the points out for the petronix.
PLANS- would like a 44 for the front( high pinion 60 , narrowed down if i hit the lottery) mildly built efi 5.0 or 5.8 . keep the outside looking as stock as possible but putting in some creature comforts. I have remote start on my 07 F-150 and love it. i have an extra set of doors , so i can cut the frame off the top of one set , for when i have the top off . and rebuild the best set for top on.
once in the shop the body will leave the frame . maybe.... huh.. not sure.
i'm probably rambling. but for now finish the insulation and plywood the walls , then pull it in(with chocks in place , don't want to add another door out the back) from that point it will be the cancer inspection.
later,
Shon
sounds like the rest of us. (addicted)Confusedupergrin: when you get it in the shop you need to start a build thread. :beer:
Looks like you've got a great place to work on it. Keep us updated with your progress and Good Luck :xyxthumbs:
well i picked up a 74 so i'll add a link. already looking forward to the 2010 meet and greet.
http://cid-8c4a8146d7fc22f4.skydrive.liv...C0%20parts
c-ya
shon
Man, that's a nice shop!! Looking forward to seeing that thing at the next M&G!! :xyxthumbs:
Dang shon has it going on !!!! :biggthumpup:
  New to CB4x4 and new to the bronco world! wydow 6 3,611 10-24-2013, 12:33 PM
  1st Bronco and loving it 1st Bronco 1 1,766 08-03-2013, 10:45 PM
  Bronco Steering wheel zack smith 0 1,606 04-03-2013, 10:52 PM
Last Post: zack smith
  Welcome Bronco Mark from Matthews, NC medwards01 2 2,076 03-27-2010, 07:05 PM
Last Post: trkbilder
  New from NC with some Bronco II's! Mtrhd0024 11 5,536 04-27-2009, 10:11 PM
Last Post: Mtrhd0024
  New to Club, New 69 Bronco Wagon SCNative 19 10,287 03-10-2009, 05:04 PM
  New Guy & Bronco SS 454 MudDevils 6 3,589 12-19-2008, 06:45 AM
Last Post: MudDevils
  Not really a Carolina Bronco mjrchode 8 3,838 02-18-2008, 11:43 PM
Last Post: mjrchode
