what exhaust and pipes should I run
Hi, guys I am running a 302 ho slightly cammed with three in long tube headers. I was wondering what the best size pipes and what muffler I should run to get the best sound and performance. I figured a three chamber and 2.5in pipes but I want to check with the pros before I go and order anything. Thanks guys.
B
common guys its been a week and no one can tell be about the right size pipes to run to make sure I have the right back pressure or not. I guess the muffler really doesnt matter, but I'm sure pipe size does.
I think big pipes sound better. But smaller pipes give better off idle torque. With a 3" collector on the header I'd say the 2.5" pipes would be fine. You want the exhaust to have the smoothest route possible. So if you went with 2.25" pipes, your tubes would dump into a 3" then neck down to the 2.25".
The rule of thumb for pipe size (bigger is not always better) is this,
2.0" pipe for 100 - 150 cubic inches per pipe and 100 Bhp per pipe
2.25" pipe for 150 - 175 cubic inches per pipe and 160 Bhp per pipe
2.5" pipe for 175 - 230 cubic inches per pipe and 200 Bhp per pipe
3.0" pipe for 230 + cubic inches per pipe and 300 Bhp per pipe
Most important is the pipe diameter from collector to tail pipe needs to be the same so you dont "confuse" the exhaust and create turbulence. In other words don't neck the pipe down to fit muffler inlet and outlets.
Bigger pipes flow more volume but the velocity goes way down which does more harm than good. You need some back pressure to create velocity and scavage the system. So for a 302 = 151 cubic inches per pipe (assuming you have dual exaust) you are right in between a 2.0" and 2.25" pipe diameter. I would think for your application 2.25" would be a good choice because that gives you a little wiggle room to add more HP upgrades without out growing your exaust system. I think 2.5" pipes might be too big for your 302 and you will loose a little HP and torque due to not enough back pressure and low exhaust velocity.
Just my .02, hope it helps.
Bill
Yea, what he said!! :xyxthumbs:
  URE Fall Run 2012? scbronco 49 18,232 07-24-2012, 08:19 PM
  Exhaust gumby93 2 2,497 04-20-2012, 05:17 PM
  6th Annual November Run - Photo Pucket Link UTFLIWGYA 1 2,388 11-13-2011, 11:00 PM
  It does run snipes243 5 3,126 10-18-2011, 10:03 PM
  white smoke from the exhaust?? blazinchuck 29 10,491 01-23-2011, 10:57 PM
  exhaust ideas firefighter2134 6 3,200 07-22-2010, 04:58 PM
  me and my boy playing pipes blazinchuck 8 5,712 06-01-2008, 01:28 PM
Last Post: redsblue73
  351W Exhaust Upgrade 73Bronc 9 4,311 01-14-2008, 11:57 AM
Last Post: 73Bronc
