My first "fab" work ... kinda
My high lift has had no foot ... so I took some 1/4" x 4" wide steel and cut two peices 6" long welded them together and some old tabs I had laying around and made this :rubeyes:
[Image: moregoods011.jpg]
:popc1:
Its a nice start JP, but I would weld another peice to it too make it thicker. That looks like it would bend with the weight of the truck on it. These jacks are prone to that anyway. Another good thing to take with a hi lift jack is a wratchet strap or chain. With a long travel supension it will not get the tire off the ground. I also like too keep another mechnical jack(bottle or screw type) to get just the axle off the ground. Just my 2C
Looks like your welding has gotten a little better than the last pics. Practice makes perfect. If it looks good, then it probably is good.
good job.
Nice work JP!! I knew you could do it!! :xyxthumbs:
  I think I can make them work nhopman 8 6,294 07-14-2016, 10:18 AM
Last Post: nhopman
  Stihl Chainsaw has wrecked my work schedule on the Bronco. Broncitis 10 7,496 05-19-2015, 11:55 PM
  back to work broncomatt 9 6,778 03-10-2012, 11:46 AM
  tractor work firefighter2134 4 2,940 06-03-2010, 08:41 AM
Last Post: redsblue73
  work sucked again supertoyota88 19 8,965 05-08-2009, 11:06 PM
Last Post: bone collector
  hows your work ????? broncomania 25 12,909 01-26-2009, 11:09 PM
  bronco work weekend, sort of broncomatt 3 3,325 08-10-2008, 10:42 PM
  cabinet work!!!! blazinchuck 1 2,314 11-14-2007, 09:12 AM
