Tow Bar Question
I’m heading to the beach this weekend and will be towing a 95 Wrangler with a tow bar. The Jeep has 31” tires and a 5 speed trans., can I just budge cord the shifter in neutral or should I also put the transfer case in neutral?
Thanks
i would put the transfer case in neutral as well.
[Image: Outalne_017.gif]
Unlockable hubs?
I would drop the rear driveshaft ...
BroncoMatt flat tows alot of stuff he will prolly chime in ...
From reading Jeep Fourms it's best to drop the rear driveshaft, but all gear boxes in neutral and leave the steering wheel in the unlock position. What do you guys think?
If you can dis-engage the transfer case that should do it. That would keep everything from spinning .
I have a 2000 TJ with 33's and a 5 speed that I have flat towed all over the country.
I pulled it here from New Mexico.
I put the Transfer in Neutral, Trans in gear, key to first click to unlock the steering.
I don't pull the shafts or anything else and have never had a problem towing it thousands of miles.
This is also my daily driver so if there was a problem, I would know about it.
sparkchaser Wrote:If you can dis-engage the transfer case that should do it. That would keep everything from spinning .
Gotta drop the rear driveshaft ...
Ok. thanks all.
I flat tow my eb all the time, but its an auto. No matter what I always un hook the rear shaft. Leave the steering wheel unlocked and the wheel untied. I have locking hubs up front so I can unlock them and put the tranny in park, t-case in neutral. That is just How I do it, your towing a jeep. With out locking hubs I would pull the front shaft up so there is no spinning of the t-case. Just my 2C.
The first time I towed my eb I put the t-case and auto in neutral and did not pull the rear shaft. Because the rear shaft was still turning it puked atf everywhere. I've also heard my t-case gears rubbing when towed with the rear shaft on but auto in park and t-case in neutral. Now I always pull the rear shaft. I say pull it, I unbolt it from the axle and tie it up to the saftey loop.
  Tow Rig??? scbronco 17 7,928 03-11-2012, 08:30 PM
  Trailer question krazybronco 7 6,321 11-30-2009, 12:39 PM
Last Post: josephitguy
  New tow rig cuz1 21 9,217 06-12-2009, 11:59 PM
  tow rig pics. broncomania 12 5,332 05-18-2009, 12:06 PM
Last Post: DeTowman
  Let see those Tow Rigs!!! blazinchuck 43 16,134 03-20-2009, 03:33 PM
Last Post: Timstrk
  carb question Bronconrocks 6 4,506 09-12-2008, 10:34 AM
Last Post: Timstrk
  460 question etc Badass 13 5,675 07-07-2008, 08:43 AM
Last Post: trkbilder
  School bus tow rig cuz1 37 13,353 07-03-2008, 10:01 PM
Last Post: cuz1
  Have an odd carb swap question Ogeechee 4x4 27 10,802 05-02-2008, 12:01 AM
Last Post: Ogeechee 4x4
