Need some help with lights dimming???
I replace the alternator in my Bronco tonight and took my little Bronco out for a drive. When I took it out for a test drive to make sure that everthing was ok the lights at first was very bright then all the sudden went dim then went bright back to dim. The voltage gauge was jumping back in forth to 0 to 60? So what could it be? I am thinking that it could be my regulator going bad or is it some kind of grounding? I replace the ground side cable from the battery to the engine.. Please HELP.....
I would check the regulator. Did you replace the alt. with a new one? And what was it doing before you replaced it?
[Image: Outalne_017.gif]
X2 on the regulator.
Is the '69 alt regulated internally or externally?
I have a working external regulator off my '66 if you want to swap it in.
sparkchaser Wrote:I would check the regulator. Did you replace the alt. with a new one? And what was it doing before you replaced it?
Yes I change out the alt with a new one. I was kind of doing the same thing before I change it out. The lights were just dimmer....
66stocker Wrote:X2 on the regulator.
It is a ecternal on my 69. Thanks for the offer but I went ahead and bought one. :biggthumpup:
I will let yall know if it fix the problem....
I would guess that the regulator is acting up.The last regulator I messed with would come and go with no consistant pattern.
The regulator that was on my Bronoc look to be a OEM. Confusedcratchhe:
I replaced the regulator and that fix my dimming problem.... Thanks to all:xyxthumbs:
  Whoa, no tail lights!! medwards01 4 3,867 01-08-2011, 09:49 AM
  No Brake lights.. Mill Knob 28 12,315 08-06-2009, 09:37 PM
Last Post: Mill Knob
  Rock lights? johnpaulgolf 5 5,002 06-16-2008, 11:04 PM
