KayLine soft top help.....
I have a used Kayline soft top. I am wanting to know about the hole that needs to be drill in the top door post for the vertical rod? The pdf file on how to put the top on does not show the measurements that good. So can someone show me some pic of theres and maybe the measurements. Thanks alot...
ill try to get a pic when i get home...i think i know just what you mean,chuck
I remember having the same problem when I did mine. I ended up doing it by eye. The place I measured to wouldhave been wrong for my body lines. Mine ended up next to the top of the rubber door seal.
I drilled some the other day - I'll have to dig up the directions but off the top of my head I think it is 5/8" from back and 2-7/8 from the inside lip. I'll verify that.
blazinchuck Wrote:ill try to get a pic when i get home...i think i know just what you mean,chuck
That would be Great chuck if you can get some pic so I could visualize it.
SC74 Wrote:I drilled some the other day - I'll have to dig up the directions but off the top of my head I think it is 5/8" from back and 2-7/8 from the inside lip. I'll verify that.
The Measurements that you have on the back looks right on my directions and the inside lip looks to me 1 7/8 on my sheet. Let me know.
Mill Knob Wrote:The Measurements that you have on the back looks right on my directions and the inside lip looks to me 1 7/8 on my sheet. Let me know.
yes, 1-7/8"
Are you Installing it or just getting some info?
berg bronco Wrote:Are you Installing it or just getting some info?
I am installing it. There a few things that are missing from it. I will post some pic of it tomorrow or the next day...
  BC Bronco Soft Top knoxville714 3 5,118 07-12-2016, 08:04 PM
  hard top countrywild0409 5 5,200 04-30-2012, 08:53 PM
Last Post: medwards01
  Soft Top problems!! jollygrngiant 10 5,443 11-22-2011, 12:49 PM
  Kayline tailgate Bracket dixieboyz13 4 3,389 11-02-2011, 10:37 PM
  Hard top Question 744x4 5 6,164 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Soft Top obxbronco 21 11,494 04-28-2009, 10:06 PM
Last Post: sparkchaser
