04-23-2012, 02:12 PM
i have a hard top for the EB. Right now its mounted on an old roll cage, im looking for any ideas on mounting it to the new roll cage so it can be easily removed if i wanna ride with the "top down".![[Image: Alex_Truck_017.jpg]](http://i1153.photobucket.com/albums/p511/astead0409/Alex_Truck_017.jpg)
hard top
04-23-2012, 05:24 PM
i dont understand "mount to hard top" they welded the halfcab top to the cage?
i guess you have to cut whatever is holding the top to that cage...then test fit it on your...but you look like you have a full cage, so that means you'll probably have to trim the back side of the halfcab to make it fit. as for a quick way to remove it...you're gonna have a row of bolts in the windshield and a couple in the back corners. nothing to quick about those. after all, you're gonna want it mounted good enough to drive with right?
04-23-2012, 10:02 PM
Ok, I have to see more pics of this ride of yours. Looks like bypass shocks on the rear!!!
You could bolt the front section to the windshield frame, if nothing has been cut away from the leading edge of the top already. The rear section could be bolted to the quarters, no? I'd just cut the whole rear window section out of the top, if it hasn't been done already.
04-28-2012, 05:29 PM
measure measure measure... then pray
My Build Thread-
http://www.carolinabroncos.com/forums/sh...php?t=3919 You're gonna have to be more specific... 11/12/11
04-28-2012, 08:38 PM
Sell the Half Cab and purchase a brand new soft top from Bestop.......
04-30-2012, 08:53 PM
broncosbybart Wrote:Ok, I have to see more pics of this ride of yours. Looks like bypass shocks on the rear!!! Hells yeah....We definitely need to see more pics of that bad boy!!!
| BC Bronco Soft Top | knoxville714 | 3 | 5,130 |
07-12-2016, 08:04 PM Last Post: blazinchuck |
| Soft Top problems!! | jollygrngiant | 10 | 5,455 |
11-22-2011, 12:49 PM Last Post: BucknEB |
| Hard top Question | 744x4 | 5 | 6,172 |
09-06-2011, 10:32 PM Last Post: Mill Knob |
| KayLine soft top help..... | Mill Knob | 8 | 4,205 |
08-12-2009, 11:20 PM Last Post: Mill Knob |
| Soft Top | obxbronco | 21 | 11,508 |
04-28-2009, 10:06 PM Last Post: sparkchaser |
