08-28-2009, 04:42 PM
Driving at highway speeds say 45 mph and above the transfer case on my 73 just kicks out of gear. Shop says the James Duff shifter is worn but I can't see how this would let it kick out of gear. Any thoughts or help?
Transfer Case Issues
08-28-2009, 05:47 PM
That is a common problem. I used a small bungy strap to keep a little tension on the lever to keep it in gear. Someone sells replacement detent springs for the transfer case. Just can remember if it was the Grave Yard or Wild Horses. They are not hard to install, but not guaranteed to fix the problem 100% of the time.
08-28-2009, 06:59 PM
thanks and I'll see what is offered.
| Adjusting Transfer Case Shifter | jdowns67 | 1 | 1,686 |
10-27-2014, 01:49 PM Last Post: Bronco Biff |
| t-shift t-case won't go into 4-lo | scbronco | 3 | 3,958 |
04-01-2014, 09:54 AM Last Post: broncosbybart |
| what transfer case | Ron Burgandy | 4 | 3,583 |
08-18-2013, 11:06 AM Last Post: 1st Bronco |
| motor issues please help!! | bigredbronco | 9 | 5,138 |
12-22-2012, 11:30 AM Last Post: bigredbronco |
| 351 issues | gumby93 | 18 | 11,131 |
09-29-2012, 07:30 PM Last Post: blazinchuck |
| Rattling/clicking noise from Transfer case | jdowns67 | 3 | 2,734 |
05-15-2012, 08:03 AM Last Post: jdowns67 |
| Power Steering issues | Crawdad | 31 | 13,330 |
07-28-2011, 09:29 PM Last Post: Crawdad |
| 90 Transfer Case Queston | 2000F150SAS | 0 | 2,960 |
03-28-2011, 10:17 AM Last Post: 2000F150SAS |
| STak 4x4 Monster Transfer Case | josephitguy | 2 | 2,339 |
01-20-2011, 12:41 PM Last Post: JayT |
| Need help with transfer case install | 73Bronc | 34 | 16,960 |
08-18-2010, 11:45 PM Last Post: 73Bronc |
