experinced concrete mixers
I will be having a new metal building put up. Before I can do that I need to tear my old barn down, then cement in the spaces in the concret slab where the beams had been. I have almost no experiance with mixing cement or pouring it.
Does anybody on here have much experance doing this?
A good tutorial would be great.
Thanks,
do you plan on just getting the 40 or 50 lb quickrete bags and patching the holes?
Yes, I bought a bag of that plus 4 bags of sand (that was what the bag said I needed) to block in a wall. I am no longer going to use it for that wall so I figured I would use it to fill in the spaces where the beams are right now.
Not sure if I need to mix in some gravel or not? It will be easy to use a board from the barn to make the form against the slab. Just not experianced with mixing, pouring, smothing (leveling?) like this.
Tips, suggestions,?
do you have mortar or gravel mix?
you must have the mortar mix already. I would not reccomend using that in the floor - I'd go buy the quickrete or readymix with the gravel already in it. Just mix it so that it is a good medium mix - not too wet (it should not slop around). You want a good firm mixture. Just pat it with the back of a shovel or side of a 2x4 - that will work the aggregates down and slurry to the top. When it gets firm you can take a normal broom and brush it for the broom finish or take a trowel when it's still wet and slick it off.
HTH
SC74 Wrote:you must have the mortar mix already. I would not reccomend using that in the floor - I'd go buy the quickrete or readymix with the gravel already in it. Just mix it so that it is a good medium mix - not too wet (it should not slop around). You want a good firm mixture. Just pat it with the back of a shovel or side of a 2x4 - that will work the aggregates down and slurry to the top. When it gets firm you can take a normal broom and brush it for the broom finish or take a trowel when it's still wet and slick it off.
HTH
X2!
Make sure the spots where the posts were have a good, solid base. Patch should be as thick as the slab around it. Use a 2x4 as mentioned above and screed off level with surrounding floor.
Tim
[Image: 2rwp56f.png]
comercial grade quickcrete
masonry cement
type S
That is what I bought, I'll be stopping by the lowes(next door to the dealership) and grab a bag with the gravel already in it.
As I can tell I have 15 spots to fill in, the largest being about the size of a cinderblock(3 of that size hole). The rest are 4"x6". I'm hoping to get them set up and poured in a weekend. That is of course if I can get the wood out of those spaces at all.
Should be an experiance either way, I was 12 the last time I poured concret.
Thanks for all the help and advice.
