6" Lift - Bushing or Drop Bracket
If i run 6"+ lift springs on my 79 Bronco and 7 degree c-bushings do i need radius arm drop brackets? Or should i run a lower degree c-bushing and the drop brackets?
Thanks
It realy depends on what type of wheeling you want to do. Lower degree bushings and radius drop brackets will give you the most flex and handle good on the highway. The only downfall is the brackets do hang down and can get caught on rocks. Just the 7 degree bushings will flex ok, not handle quiet as good on the highway, but wont get caught on rocks(its also a whole lot cheaper). Personaly I would only do the drop brackets with longer arms. just my 2c
It's a street truck with a couple of trips to the beach and that's it. I was thinking 4 degree with the drop brackets
F1504x2 Wrote:It's a street truck with a couple of trips to the beach and that's it. I was thinking 4 degree with the drop brackets
I would go with that. I got the 6" with the drop brackets and 4 degree bush. Does great on the highway.
jollygrngiant Wrote:I would go with that. I got the 6" with the drop brackets and 4 degree bush. Does great on the highway.
x2 :beer:
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,513 09-19-2018, 02:50 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,981 01-31-2016, 03:55 PM
  Ideas for hauling a Hi Lift jack? Broncitis 6 4,481 06-19-2015, 05:03 PM
  Radius arm bushing cause of grinding/vibration sound? 1st Bronco 7 4,385 09-13-2013, 09:47 AM
  Kayline tailgate Bracket dixieboyz13 4 3,389 11-02-2011, 10:37 PM
  bushing install ? firefighter2134 2 4,119 08-11-2011, 10:30 PM
  Lift & Tires??? scbronco 9 5,301 05-22-2011, 09:27 PM
  What is this bracket? Crawdad 5 3,176 02-26-2011, 12:05 AM
  TTB lift question jdowns67 7 4,717 11-20-2010, 09:36 PM
  Bushing source for EB brake booster chuzie 3 4,161 07-12-2009, 08:10 PM
