mustang new power plant
302 based stroker motor. svo R block, billet crank & rods, low compression, big big stick, internal balanced, yates heads, 88mm turbo.
estimated 1300hp it made 1200 at 15 pounds of boost when it was in my buddies car. he ran a 512 spinning at around 140mph in the 1/8th mile.
[Image: 2670366210101201698S500x500Q85.jpg]
[Image: 2845122950101201698S500x500Q85.jpg]
[Image: 2059563960101201698S500x500Q85.jpg]
Mike that is awesome.
How hard of a hookup will it be in your car?
[Image: Outalne_017.gif]
now i see why the bronco is history
holy exhaust pipes batman :wowcb:
I bet that exhaust run took some time. Thats one sweet looking small block.
Are you gonna run similar boost in your setup or are you planning on tweaking things yet before you squeeze it under the hood?
Yipes!! That is some serious hp!!! :xyxthumbs:
Have You had It on a dyno just curious? What type of rpm range does it run?
pretty bad ass mike
it was on a dyno when it was in my friends mustang. i plan on re tuning everything when i get it stuffed under the hood. it should be an easy swap. the EFI electrical will be the hardest part but it comes with all of that and the electronics to. ive got to buy an ice box and intercooler. thanks.
I wanttttttttttttttt
ALMOST READY!!!!!! ELWOOD
302 with an octopus trying to eat it. Who would have thought a small block could put out that much HP. Very sweeeeeeet indeed.:popc1:
Oh wow! I'm so jealous.... Now I want to buy the EB even more.... (wish I had that cash right now)
  92 mustang build broncomania 128 61,655 12-10-2009, 09:36 PM
  94 Mustang 800+ RWHP 66stocker 7 6,628 07-28-2009, 07:01 PM
  buildin power blazinchuck 15 7,161 10-25-2007, 10:32 PM
Last Post: trkbilder
