spit and sputter with 70 EB
My 70 half cab has started to spit and sputter when I take the pedal to the metal. Seems like 3rd gear is worse than 2nd which is worse than 1st. I have rebuilt the single barrel carter carb, including accelerator pump, set the timing and the points, and installed a manual choke......still no luck in solving this problem. Any ideas??? TIA...
Time, Money & Effort
Laurens County, SC
Seeing how is sounds like the sputter is worse with more load, I would start with the ignition before moving to the carb. What do the plugs and plug wires look like?
The plugs looked ok to me, but I bought a new set, confirmed the gap and installed them with no improvement.
What kind of ignition issues should I be looking at? Thanks.
Laurens County, SC
and the wires are new. no vacuum leaks identified, either.
Laurens County, SC
Cap condition? Plug wires? Any burns, cracks, or white chalky residue from arcing? Also you need to check the impedance of wires to make sure none of them have broken into inside the insulation.
will do, thanks bucket!
Laurens County, SC
how old is the coil? what does it do under no load in neutral when you rev the rpm's up - nothing?
don't know about the age of the coil, i need to look at that as well. thank r
Laurens County, SC
  sputter? berg bronco 10 4,405 01-01-2009, 06:34 PM
Last Post: berg bronco
