Help- Electrical & Art Carr Shifter
Info: 1974, V8, auto c4
Help! I'm in the process of installing a Art Carr floor shifter. I need to install the neutral / park safety switch and can't find the electrical connection information. Does anyone know how? I also have a plug and no apparent connection. The wires are light purple/light purple? Any Suggestions? Where is the best place to find electrical Wiring diagrams?
Thanks, Shep
Confusedcratchhe::banghead:
I installed one but did not hook up the NSF. It was Sorry I can't help, but you will love the shifter.
do I need it?
do I need it?
All it does is prevent you from starting the ignition when you are not in park or neutral. It is safer, but do you NEED it - not really.
Do you need to do anything with the original column shifter or electrical? Thanks
sorry for the double post earlier. I hit post twiceSmile
That I don't know - I installed mine during my auto conversion so I never had an auto column to start with. I imagine that you would have to connect the old NSF wires so they are permanently "off".
When the plug is not there it doesnt care either way.Mine still dangles under the floorboard not connected to anything 21 yrs after I got it in 88
03 Honda Shadow Spirit
  ARB compressor electrical connector snipes243 3 4,480 12-04-2015, 01:48 PM
  Adjusting Transfer Case Shifter jdowns67 1 1,690 10-27-2014, 01:49 PM
  electrical help scbronco 6 4,269 11-21-2011, 12:52 AM
  93 Full Size Electrical Problem BigBird13 0 2,499 07-18-2009, 01:51 PM
Last Post: BigBird13
  np435 shifter help . broncomania 2 2,857 06-01-2009, 12:39 AM
  electrical problem berg bronco 10 6,565 11-17-2008, 08:41 PM
