electrical problem
Heh guys when I step on my brake pedal the right brake light comes on and the front left turn signal comes on. I have checked for bad ground and have all new bulbs. if you have any advice i would appreciate it.
what does it do when you have the running lights on? that sounds odd,Chuck
It honestly sounds like a wire has chaifed threw. Check the harness where it runs along the the rear of the frame. If the brake wire has rubbed threw too the turn signal wire it could back feed to the front one. Also, check to see if the trailer wiring pigtail is damaged.
should he check for continuity between the two lights?
For the brake signal to go to the front the wire must have come in contact with the turn signal wire. I would think there would be continuity between the turn signal terminals, assuming the turn signals
still work.
By the way berg, what year bronco are we talking about?
It does the same thing when the lights are on everything works the way it should Ive looked at the wiring in the back it all looks good when I put my tester in the rear connectors im getting power through the ground
with the brake switch on
its a 71 sport the turn signal cam is working the way it should
I'd look at the left rear tail light again. I'd double check the bulb and the socket.
I had a similar problem once on Trans Am. All lights appeared to work correctly, except when ever you would apply the brake or right turn signal the headlights would flip up and down. Had a fault "new" bulb with the elements crossed inside. So it would back feed the park lamp circuit when ever the bright side was powered.
bucketobolts Wrote:I'd look at the left rear tail light again. I'd double check the bulb and the socket.
x2... faulty bulb.
Hey guys thanks for all the advice. I think I might need a new tailight housing I am also thinking of getting a new wiring harness. Are they as good as they say they are, are they pretty easy to install and which one do you guys recommend?
  ARB compressor electrical connector snipes243 3 4,477 12-04-2015, 01:48 PM
  Sticky Throttle Problem SC74 18 7,522 02-09-2012, 05:41 PM
  5.0 backfires - problem solved! SC74 50 20,798 01-17-2012, 03:18 PM
  electrical help scbronco 6 4,262 11-21-2011, 12:52 AM
  Help- Electrical & Art Carr Shifter jrshepherd 7 6,262 11-12-2009, 09:58 PM
Last Post: 744x4
  Battery Problem???? Start slow..... Help... Mill Knob 22 8,790 10-01-2009, 01:03 PM
  Need advice on tube flaring problem... chuzie 8 3,960 08-28-2009, 05:42 PM
Last Post: 66stocker
  93 Full Size Electrical Problem BigBird13 0 2,499 07-18-2009, 01:51 PM
Last Post: BigBird13
  problem with my 79 fordfan 4 4,372 01-04-2009, 10:04 PM
  Headlight problem fomoco 8 4,330 03-31-2008, 11:49 AM
