UNCUT EB Tire Size?????
OK. I have a 77' Uncut EB. It has a new 2 1/2" Lift with new Springs and Coils. I have 15" Rims with the Original Hubcaps. This is fine for in town and the usual Meet-N-Greet, but I want to put a set of more "agressive" tires and wheels on it that I can take in the sand/trail.
Keep in mind, cutting the fenders is not an option.
I'm looking at purchasing 31x12.50x15 All Terrain Tires (Pep Boys has a buy three get one FREE thing going on...) but I'm not sure if they will have enough clearance width wise from the fenders.
Anyone ever had the same problem? Please let me know what size tires have worked for you. Thanx
FWIW- Before I cut my fenders I had 35x12.50 with a 5.5" suspension and 3" body. It was not too bad unless I really jammed them in there.
ya better look for 9.5 or 10.5 wide on the tires...
i saw one at tellico a few yrs ago at meb fall crawl that had 5.5 inch lift running 35 10.50
those tucked up nicely in the fenders. they was mounted on stock rims and hubcaps.. it performed really well on trails though with no sheetmetal damage!
Thanx for the helpful hints everyone!! I hope to have some on before too long!!
runnin 33x10.50 on my uncut with 3.5" lift on the stock wheels. they tuck up nice inside the wheel wells...i'm thinkin if you go to a 12 inch wide tire and a 2.5" lift you are gonna get some rubber in the sheet metal.
  tire balance Timstrk 4 5,146 11-05-2015, 01:57 AM
  Can firing order determine engine block size? 1st Bronco 1 2,014 08-16-2013, 06:26 PM
  Tire question dixieboyz13 12 7,811 08-25-2011, 01:58 PM
Last Post: ncsubronc
  spare tire mount snipes243 12 8,384 11-28-2010, 06:05 PM
  Tire tech johnpaulgolf 11 7,252 12-04-2009, 01:15 PM
  93 Full Size Electrical Problem BigBird13 0 2,490 07-18-2009, 01:51 PM
Last Post: BigBird13
  doors on the full size supertoyota88 4 2,866 05-05-2009, 01:08 AM
Last Post: supertoyota88
  good tire supertoyota88 4 2,951 05-02-2009, 01:28 AM
  Tire cut? johnpaulgolf 6 4,951 05-13-2008, 09:46 PM
Last Post: Ogeechee 4x4
  full size buckedupbronc 8 6,797 11-04-2007, 09:14 PM
