Can firing order determine engine block size?
I have a 1989 block (E9AE-8015-AA-82-D9) in a 1985 Bronco (VIN# 1fmdu15hxfla17630) I just acquired. The firing order is 13726548. In my Haynes is lists the 351 having the same firing order and the 302 having a firing order of 15426378. May sound like a foolish question but is it safe to assume I have a 351 and not a 302? I only ask because the seller of the Bronco said he was told that it was a Jasper 302 under the hood when he bought it. Very pleased with my first Bronco and drive it daily....just want to be able to talk intelligently when I walk into the parts store.
Thanks,Confusedcratchhe:Confusedcratchhe:Confusedcratchhe:Confusedcratchhe:
VIN# makes it a 1985, the engine block# is an 1989, and the front end is from a 1987. I call it Broncenstein. [Image: bronco.gif]
302HO's shared same firing order as 351's...standard 302's had diff firing order. did you look at cap and determine what firing order you have now? usually there is a #1 marked on the cap...and you have to go counter clockwise to check. 351's have a taller deck height and the intake should be a little wider than a 302. that block number you listed should tell you everything about the block. google ford engine block numbers to help break it down.
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 6,091 05-15-2014, 11:50 AM
Last Post: rbodine
  Engine help snipes243 12 6,462 02-21-2014, 12:06 AM
  5.0/nv3550...engine now dies at stops*help* blazinchuck 14 7,052 06-09-2013, 10:50 AM
  cummins to a ford small block standard trans adapter plate Rdnckdemo 2 2,510 04-14-2013, 01:19 AM
Last Post: Rdnckdemo
  1996 5.8 L Engine Rebuild- Cylinder heads jrshepherd 0 3,424 07-17-2011, 11:13 AM
  Engine Rebuild. 1996 5.8 L jrshepherd 0 1,744 05-05-2011, 02:02 AM
  UNCUT EB Tire Size????? UTFLIWGYA 5 5,998 08-23-2010, 02:14 PM
Last Post: ncsubronc
  93 Full Size Electrical Problem BigBird13 0 2,499 07-18-2009, 01:51 PM
Last Post: BigBird13
  Determine gear ratio chuzie 17 12,509 07-13-2009, 10:15 PM
  new engine berg bronco 21 9,136 05-12-2009, 11:38 PM
Last Post: supertoyota88
