hydro boost
im thinking of doing this mod to my bronco. heres what i have on my bronco now. its 71 with the james duff vacuum brake conv.http://www.jamesduff.com/eb/booster.html with toms power steering conv.http://www.tomsbroncoparts.com/product.p...y=69&id=87
with the stock proportining valve and drum brakes in the rear and disc in the front. my question is what do i need besides the hydro boost and the hyd. lines? can i reuse the master cylinder and the prop. valve?
When I did the hydroboost conversion on my rig, I started with the angled bracket and attaching the booster to it. Then I used a Corvette master cylinder because I was using 4 wheel discs. I left the factory H block and added an adjustable proportioning valve in the rear circuit. I purchased adapter fittings to allow the use of AN style fittings on the hoses Both of my hoses ended up being close to the same length and had the same fittings. Made carrying a spare real simple.
thanks! im trying to figure out what I can and cant use to get a cost together to see if its feesible.
I saw this out west in AZ Bronco website. It may or may not help you. Just wanted to atleast pass it on to ya.
http://www.azbronco.org/tech11.htm
Don't rule out a Ford powerstroke hydroboost unit. That's what I used on the crawler and the mounting was very easy. I ended up moving the brake pedal over to the clutch pedal position and it lined up like a charm.
  hydro assist smitty 9 5,489 05-15-2009, 08:56 PM
Last Post: Timstrk
  JunKeBluB2 Hydro-Assit JunKeBluB2 11 6,346 10-22-2007, 01:54 PM
Last Post: JunKeBluB2
