05-14-2009, 02:02 PM
any one got any build threads or pics for a hydro assist? thinkin about doin it on my 79 bronco.
>S.M.I.T.T.Y<
hydro assist
>S.M.I.T.T.Y<
05-14-2009, 06:38 PM
well, to start you will need a ram, brackets, hoses,and a drilled/tapped steering box...and might have to upgrade steering pump. I have a hydro box, but dont think it would work for you...its off a 87' bronco(probably different style)
05-14-2009, 07:00 PM
ive found some build threads on it and got where i need to drill and tap... i just wanted to see it done on a few ppls truck to figure out a way to mount the ram on mine... i also plan on doin the weldanator that was on a build thread to...
>S.M.I.T.T.Y<
05-14-2009, 09:15 PM
is that the home built welder/alt??? i remember that...
05-15-2009, 02:01 AM
yea...off of nc4x4... im goin to start these 2 projects soon.. im thinkin about also doin the trail proof steering system from broncograveyard.com i havnt heard any about them yet though...
>S.M.I.T.T.Y<
05-15-2009, 09:44 AM
You can build one better and cheaper by yourself. Off the shelf parts and tubing from any steel supplier. PM and I'll give you all the info you need to save hundreds of $$.
Tim
05-15-2009, 10:18 AM
Timstrk Wrote:You can build one better and cheaper by yourself. Off the shelf parts and tubing from any steel supplier. PM and I'll give you all the info you need to save hundreds of $$. Really cratchhe:... sounds like I need to make a weekend trip to your house Tim for some hydro assistance upergrin:
Always an EB fan, lover and freak :notworthy: 1985 Yoda 4Runner :xyxthumbs:
05-15-2009, 08:56 PM
The green box on Westtexasoffroad.com is mine. You can look at it all you want but the pics on his site won't show the tap points. Thats where he makes his money. Knowing where to tap. You can look at my steering box and try yourself if you want. I can very much help with the tie rods/drag link/panhard bar. Those are easy.
Tim
| Who is using Surplus Center for ram assist cylinder? | chuzie | 6 | 3,550 |
08-16-2015, 09:30 AM Last Post: chuzie |
| hydro boost | berg bronco | 4 | 3,802 |
01-05-2011, 10:22 PM Last Post: SC74 |
| JunKeBluB2 Hydro-Assit | JunKeBluB2 | 11 | 6,467 |
10-22-2007, 01:54 PM Last Post: JunKeBluB2 |
