Water pump questions for 351W
Has anyone had problems viewing their timing marks on their 351Ws? My original water pump and hose covers this up. What do I do? Get a water pump that pours out on drivers side and pipe it underneath?? Any advice or links to fix would be greatly appreciated! :beer:
Depending on what the 351W came from, it could go either way. Where is the timing pointer located? On the driver's side, or pass side?
I cheated on mine. I wanted to use a stock type radiator. My water pump inlet went toward the driver side, on the donor engine. I removed all the accessories off of it (fan, belts, pulleys), and ran it for a minute or so (not long as it had no coolant in it) to get it timed right. Then I took the water pump off and got a new one with the inlet on the pass side. It covers the timing mark up, but I don't care... To do it right you would need to replace the timing cover, water pump, timing pointer, and harmonic balancer with an EB setup. Everything from the EB 302 is 28oz balance, just like a 351w is, so you would be good to go.
broncosbybart Wrote:Depending on what the 351W came from, it could go either way. Where is the timing pointer located? On the driver's side, or pass side?
My uncle said the timing marks are underneath. He too said to crank it w/o all the pullys and stuff but was really hesitant on doing that. I'd like to view the timing marks from up top. How can that be done??? I have plenty of old longblock 302s!!! I figure since I'm replacing the cam I might be able to change the location of the timing marks too.:banghead:
UPDATE: I bought a FlowKooler (#1681) this afternoon for $80. Also got new hoses for $35. Should be here by this weekend.
You probably just need the correct ballancer and pointer for a passanger side inlet pump. Do you have a 3 or 4 bolt pulley?
  A few questions for you guys Jbass 20 8,808 03-24-2014, 05:21 PM
  Bestop Soft Top Questions broncosbybart 0 1,666 03-13-2013, 02:14 PM
  Interior questions N747JB 14 5,641 10-21-2011, 09:15 PM
Last Post: N747JB
  Bronco build questions AReed 12 6,112 03-23-2011, 04:12 PM
Last Post: AReed
  Doubler/axle moved forward Questions blazinchuck 11 6,063 04-30-2009, 08:32 PM
  A couple of quick Questions brewie212 3 2,785 02-18-2009, 12:10 AM
Last Post: brewie212
  302 water pup pulley/2 grooves Jabo76 5 3,520 07-29-2008, 09:55 AM
Last Post: Jabo76
  Explorer Serp Conversion (PS Pump?) chuzie 1 1,867 04-06-2008, 03:30 PM
  351W Exhaust Upgrade 73Bronc 9 4,245 01-14-2008, 11:57 AM
Last Post: 73Bronc
