Let's talk flywheel's
the bronco is 164 tooth with 11" clutch correct? just wanted to order parts before i pulled mine. and i still need to fix the linkage snafu from the super celebration. I will probably keep the 72 now but the 69 may be up for grabs still.
I think my rust is rusting...
v8's came with 10 or 11 inch clutch and some I6s came with a 9 inch clutch
thanks. I will pull mine to confirm.
I love fed ex and ups !!! just unloaded the new flywheel , clutch kit , and my fender bolts from Jeff's . hopefully I can tear into it this weekend.
sweet. at least someones wrenching on a bronco
it was 164 and 11" and works wonderfully now that there are no 1/8 cracks in the flywheel. now to get the carb and timing adjusted correctly. no timing mark to set it by...guess i need to brush up on the old school vacuum technique........
  Talk to me about snorkels Ogeechee 4x4 5 3,405 09-17-2008, 11:20 PM
Last Post: Ogeechee 4x4
