looking for some 5.0 advice
just got a call...friend is offering up a trickflow stage 1 cam...
pretty cheap, could i install this and run it without any issues from the computer? I also have a explorer GT40 intake I was looking at installing too.
I dont wont any run-ability issues with a cam swap...so i need some of your advice please
The best thing to do is compare the cam lift and duration. I'm sure you can pull that info right off Summit racings web site. If the lift and duration is just a bit taller that I would go ahead and put it in. The ecm will adjust itself and the intake and upper pleanum should be closely matched to that cam.
I am with Matt. Just be sure to have your die grinder ready to cut out a section of grille when you install the cam Big Grin
  Advice on purchasing a sand blaster Crawdad 13 5,620 06-29-2011, 09:04 AM
  Advice on replacing an oil dipstick/ tube Crawdad 6 3,064 02-02-2011, 09:58 AM
  locker advice. broncosbybart 6 2,876 01-05-2011, 02:39 PM
Last Post: abunchofidiots
  I need some advice..... Mill Knob 16 6,588 07-21-2009, 12:03 PM
Last Post: ELWOOD
