Dyno'd the 77 today!
after some aggravation with the steering column, decided to ride out to my buddy's shop. they wanted to put the bronco on the chassis dyno...so i said ok
she put down 210hp/245tq...i was hoping for more, but thats still not bad,
anyway to figure out what my loss is going thru a nv3550,d20,9"(4.56) and 33" tires? so i can kinda put a number on the motor.
they printed out my run, but my scanner is down.
fuel pressure held 42, and the wideband showed my running a touch rich...i think 12.8
[Image: photobucket-3245-1351391151161.jpg]
Hell yea Chuck. What do you think motor only is?
Chuckles and I went back and forth on that last night. Typically looking at 15% loss from crank back for street cars with manual. Fellas on classic range from 20 to 28%. I would venture to say 24% is a fairly decent estimate for chuck since he does not have crazy tires or anything. So with 210 @ wheels we might estimate 260 HP @ crank. I know he was hoping for more though with the bore, came, etc. Could be simple mods though.
What do you think a stock 5.0 would be - at crank and at rear wheel?
My guess on the stock 5.0 is about 200??
That is really cool chuck!!
Actually the stock 5.0HO (MAF + 60mm TB 1989-1992) was 225HP (FWHP) @ 4,000 RPM which was beaten by the Cobra variant in '93 with 235HP (according to the government) but it was really more like 265HP.
im not digging the power curve tho...it should 1500-2000 lower for rock crawling...oh well guess i got a mud rig now lol
I wish there was an app so we could dual post between forums with one click. Smile
as soon as i can finish the steering column, cruise control, ac/heater...my boy shawn got me a chip/flip switch/data cable...so i need to get up to his shop so they can write a custom tune for the 77. might net a few more ponies!!
Thought id bring this back up. Dynoed the 77 again last night. I fixed a leaking brake booster and got the 65mm throttle body/70maf now. My buddy got me a chip/switch/data cable. So base run was 213/246. Found fuel too learn now- so he tweaked it up a couple times, then on 3rd run added 2° of timing.I'll post pic of the computer screen. The last row of numbers were a comparison to my buddies stang. Guy told me I can easily run 87 now or anything. I was worried bout that and have been running mid grade since installing the 306. He also added another tune for a9l...since I'm using a a9p now. So if eec crashes I can use either and still have the tune. Ended up with 242/275 at the tires! Not bad at all. And just for kicks... I brought a pair of my f150 tires/wheels(235/75/15) another run show only 6hp/11tq increase.
Now what's interesting my buddy's stang has gt40heads/intake/tf stage 1 cam(same as me) and shorty headers.
I have same intake/tf alum heads, same cam, more compression w/dome pistons. His before and after 240/289...260/306 with a 5sp.
So I'm sure my motor is making more power...but I'm losing a good bit thru 9",d20,nv3550... so hope this sheds some light on things.
Getting a tune if very good!!! I could have hurt my motor running as lean as I was I think.
Sent from my DROID BIONIC using Tapatalk
  what have you wrenched on your bronco(s) today? firefighter2134 2,039 646,379 03-27-2017, 11:17 AM
  Ruff 76 I looked at today. Broncitis 20 10,422 09-05-2015, 08:49 PM
  The Bronco made the news today snipes243 8 4,167 08-24-2015, 12:45 PM
  Found an uncut bronco rusting away today. 72_EB_GUY 3 3,965 09-14-2014, 09:56 PM
Last Post: 72_EB_GUY
  Ran down another bronco today Crawdad 2 2,927 09-13-2014, 10:59 AM
  Went and looked at a bronco today Crawdad 27 9,985 01-22-2014, 09:35 PM
  Visiting Wild Horses today. BucknEB 7 5,687 12-11-2012, 11:54 AM
Last Post: Carolinaoffroad
  New Project started today 744x4 71 23,235 08-24-2011, 08:13 AM
  Got My Boy a Bronco today Mill Knob 28 12,097 02-22-2010, 02:49 PM
  drove my bronco today broncomania 6 3,210 06-25-2009, 11:05 PM
