Park Lights
[Image: 8f9273f3da899c2bff6a846a24cc6997.jpg][Image: 8c4fbe96336c07fa0d6b0deb6379be1b.jpg][Image: 853de9644d6edfd953244097258ccfba.jpg]Finally got around to putting the lights in my grill.
Sent from my NEC-NE-201A1A using Tapatalk
I used some metal that came from a Suzuki packing crate which my nephew who works at the Honda shop here had. Worked out great,
Looks good Dwight
Bart I have found the smaller park light lenses that you wanted and will try to remember to bring them when we meet u again. They are the clear ones.
Did u do the early light MOD? Hard to tell in pics
Sounds good. Thanks Dwight!
How a about a pic or 2 in the day where we can see a bit more of what you did?
I'm curious and I think others probably are too.
Yes Chuck I had ordered some clear 66-68 lenses with plans of modifying my old buckets to fit them. When i looked closer at my old buckets I decided they were not fit to use so I ordered new 66-68 lights and made u a adapter bracket to fasten the smaller housings in the original opening.I had to trim a little over a 1/4 inch off the tab in the 73 grill and drill one hole in same tab. All in all I am very satisfied with how it worked out. If anyone would like a foot of this metal I used to make adapter I have 10 or 12 foot of it and will cut them off a piece and give it to them when we have a ride or a meet. All I used to fab the brackets were a 4 1/2 in grinder with a cut off wheel and a sanding disc a flat file and a couple of drill bits. And a sharpee to draw where I wanted to cut and drill. Easy and a great result.
I do need to get some orange bulbs to put in them, they came with clear. I had some orange but when i looked closer I found that they were single element. I will try to get a couple of pics in the daylight tomorrow.
New pics of lights[Image: a2aa15b7d89391b08e8c3bf5a9a5be4a.jpg][Image: 5bc1fd94e217a58963f8091f8bfa956a.jpg]
They fit perfectly in the existing opening and are recessed about half the depth of the lenses.
Those look great, ima do that same mod soon
  12 Volt LED rock crawling lights broncosbybart 2 2,166 11-12-2012, 12:38 PM
  DIY rock lights blazinchuck 13 9,900 02-24-2012, 02:31 PM
