90 Bronco Automatic Transmission Question
We have a 1990 302 with and 3 speed automatic with OverDrive. What trans. do we have or where do i look for this information?Confusedcratchhe:
Thanks
Is there a button on either dash or end of shifter to bypass od.If so it is an E4OD.If you have to manually pull the shift lever down I think it was an AOD.
[Image: Outalne_017.gif]
Ok, great.
Thanks for the help.:biggthumpup:
if the tranny pan is L shaped it is aod i think cuz my brother tranny was L shape and it was aod now has a c6 in it cuz he didnt like the aod
GO BIG OR GO HOME!!!
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 2,195 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 3,069 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 4,705 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 2,918 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 3,434 01-31-2016, 03:55 PM
  Steering shaft Extension Question??? Broncitis 4 2,672 04-17-2015, 02:27 PM
  Another Bronco Floor Replacement jdowns67 83 12,387 12-20-2014, 11:33 AM
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 3,784 05-15-2014, 11:50 AM
Last Post: rbodine
  Exhaust question Casey835 27 6,429 08-16-2013, 06:03 PM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 2,725 08-04-2013, 10:48 PM
Last Post: 1st Bronco
