Need full width info.
broncomania Wrote:76 do have disc brakes.maybe not all of them but the ones ive stripped have had disc. 76/77 both are weld on c wedges. hp44
67" wms to wms thick axle tube.
note: the only reason for the thicker axle tube was because the c wedges were being welded on. the heat from being welded required thicker steel tube.
thanks..good to know:xyxthumbs:
So does the '78 and '79 F150's have cast wedges like the broncos?
yes
Did I ask this already, How hard is it to 4 link an axle with Cast wedges?
Would the wedges really be in the way?
Or is there a fear a weakening it with the welding done to the tube?
Traveler Wrote:Did I ask this already, How hard is it to 4 link an axle with Cast wedges?
4 linking with cast wedges should not be an issue. welding to the axle will be fine.
How would this work for a donor?
I know it will have drum brakes, but if it really has lockers that could be a steal. He is already down from $1,200.
I would assume it has power steering, is it the same box as the later trucks, so I can use it on my EB with the 2wd, worm gear change?
A bargin?
Thanks
bucketobolts on here has axle housings for sale that are eb ready and priced cheap. and ive got the shafts,carriers,gears,brakes , etc. etc.(2 complete axles ) for $350.00
What are lockers worth? Maybe I should look. He said it has 4.10 ratios and detroit lockers in the front and read. That is what really caught my attention.
Sell the snow plow off of it for $500 and it could be a pretty cheap conversion.
That is a good price, but I am not sure when I would get a chance to get those parts from NC to Iowa.
  Timed vs full??? Crawdad 11 3,987 03-02-2011, 10:52 PM
  Headers - Shorty or Full Length 2000F150SAS 3 2,150 01-27-2010, 04:08 PM
  93 Full Size Electrical Problem BigBird13 0 1,559 07-18-2009, 01:51 PM
Last Post: BigBird13
  I need to know the Radius Arm width. 2000F150SAS 0 1,031 06-17-2009, 10:00 AM
Last Post: 2000F150SAS
  doors on the full size supertoyota88 4 1,593 05-05-2009, 01:08 AM
  full size buckedupbronc 8 4,392 11-04-2007, 09:14 PM
