hand throttle
I did a real simple setup Chuck.
[Image: slimbco-005.jpg]
Mine is done and looks like that, however the shifter shaft is about 5/8 OD and the ID of the throttle is 7/8, so right now I have elec. tape to make it fit tighter. Really need a slip bushing. I post some pics later. And the funky rig I made for the carb :lol:
carb setup
[Image: slimbco-001.jpg]
blazinchuck Wrote:Mine is done and looks like that, however the shifter shaft is about 5/8 OD and the ID of the throttle is 7/8, so right now I have elec. tape to make it fit tighter. Really need a slip bushing. I post some pics later. And the funky rig I made for the carb :lol:
Yeah you can see my ghetto fab shim in the first pic.
Something told me to search before I posted a thread asking for ideas about a hand throttle... I guess I should go ahead and install one.
I have a stock hand throttle plate that goes under the gas pedal for a PTO equipped EB if you want some pictures.It is allot easier than the direct to carb route.
744x4 Wrote:I have a stock hand throttle plate that goes under the gas pedal for a PTO equipped EB if you want some pictures.It is allot easier than the direct to carb route.
That would be awesome to see how it's done.
:popc1:
mines disconnected right now...changing it up.
used an index shifter
[Image: hand-throttle.jpg]
if you need more pic pm me
Here are a few shots of the stock hand throttle for the EB.It mounts under the gas pedal and actually moves the pedal insted of using a carb linkage.
