10-14-2008, 09:10 PM
I have been putting some thought into swapping out a Np435 for my stock 72 transmission. I have never swapped a transmission before so I was wondering what all needs to be done and anything special I should know.
Tranny swap
10-15-2008, 03:20 PM
I'm guessing your replacing a stick 3 spd? If so there is not too much to installing a NP435. I would highly suggest at least a 2" body lift. I first installed my NP without any body lift. It will go but is much more pleasant with the lift. You will also have to cut a hole in the tunnel for the shifter. I cut the entire top from my tunnel and fabricated a removable cover. Like I said before without a lift you will probably have to cut most of the tunnel top out to install, but with about 2" you can brobably get by with just a hole the size of an average shifter boot.
10-15-2008, 03:25 PM
A body lift is a MUST if you want to keep your sanity. Less body mods will be required and removal and installation is a million times easier and faster.
10-17-2008, 08:30 AM
This swap will be the easiest upgrade to improve you "crawl" ratio and the 2nd 3rd and 4th gears basically mimic your 3 speed. The 1st gear is so low and I mean sooo low it will be great for increasing your crawl ratio. The NP435 is a really tough tranny also I have put mine through some really tough gear bangin hardcore shifting and have beat on it plenty...no problems...mokin:
I am pretty sure this is the adapter you will need...Chuck had one so he let me use it...someone chime in to make sure I'm right here... cratchhe: http://www.tomsbroncoparts.com/product.p...44&id=1073 This is a must have in order to do the swap...:xyxthumbs: http://bcbroncos.com/store/product_info....cts_id=176 :chili: :rockon: :chili:
10-17-2008, 10:31 PM
The adapter is a must? its expensive as hell, thats more than the tranny itself. And as for the lift, im not too worried about comfort as this is not a daily driver and i dont mind cutting out the tunnel. Thanks for the answers guys
10-17-2008, 10:40 PM
The adapter is a must!!! :grinning:
The 6cyl. adapter also!!! :blues: The lift is more for the ease of install and being able to work on stuff...:beer: I paid $100 for my tranny and $250 for the adapter...:rubeyes: Its all worth it I promise...mokin:
10-17-2008, 11:11 PM
JP is right. It is gonna cost some $$$ but it is a necessary evil.
Tire/rim swap | anthonysmilsurp | 8 | 1,756 |
08-18-2011, 12:06 AM Last Post: anthonysmilsurp |
4 speed tranny, will it work on EB | Crawdad | 13 | 2,168 |
08-13-2011, 07:56 PM Last Post: blazinchuck |
any tranny shops round fayetteville? | c-dub | 1 | 1,092 |
05-29-2010, 01:20 AM Last Post: c-dub |
Engine Swap...wanna help | UTfball68 | 4 | 2,324 |
09-17-2009, 07:57 PM Last Post: UTfball68 |
4.0 Bronco II Swap | Mtrhd0024 | 4 | 3,334 |
06-18-2009, 07:01 PM Last Post: Timstrk |
New Roll cage, tranny, sliders and fab front bumber | johnpaulgolf | 151 | 19,334 |
06-27-2008, 04:12 PM Last Post: johnpaulgolf |
Tranny is in!!! | NC-Fordguy | 2 | 912 |
01-17-2008, 05:59 AM Last Post: blazinchuck |
