4 speed tranny, will it work on EB
I'm looking at getting a NP435 (don't need it, but want it?!!!!) and I want to know if this one will work for me. I'm still getting info on it, will post more later.
The 435 will bolt in place of the stock 3 spd. Some modifications may be needed. Realy depends on what its out of. But overall it should work.
broncomatt Wrote:The 435 will bolt in place of the stock 3 spd. Some modifications may be needed. Realy depends on what its out of. But overall it should work.
Thx Matt,
Would the bellhousing from a three speed work for a NP435 4-spd?
as long as the tranny has a square bolt battern rather than the trapezoid pattern
The owner tells me the tranny is from a Ford F-250 2wd. Does not have bellhousing or linkages. 10 spline in front, 28 spline in rear. He said his 3 speed bellhousing doesn't fit the NP435.
if the np435 has the square bolt pattern then it should be the same as the stock
I'm going to look at it this weekend, will let you know. Such a good deal it is hard to pass up even if I don't have all the parts. I may just sit on it for a while.
worse case just have to find a trap. bell housing. but i love the 435 swap i done. not really different on highway but super low first and reverse. cant wait to test it off road
the 3sp bellhousing should work, and what Asiel said(square bolt pattern-not trapezoid)this pattern is the tail shaft side.
you still need an adapter 1" thick. AA makes a intermediate housing(goes between tranny and T-case) that had the 1" adapter built into the intermediate housing(very pricey though) when i did mine i looked around and bought one (1" adapter) from ebay...bout $100
1" adapter with a 6cyl housing(this makes it a simple swap) no need to move cross member
  who does your fab work? c-dub 1 2,166 08-21-2011, 10:44 PM
  any tranny shops round fayetteville? c-dub 1 1,994 05-29-2010, 01:20 AM
Last Post: c-dub
  Done some work on the Bronco .... Mill Knob 36 13,831 09-26-2009, 11:07 PM
Last Post: Mill Knob
  Tranny swap Nathan Mattar 7 4,737 11-20-2008, 08:16 PM
Last Post: Jabo76
  New Roll cage, tranny, sliders and fab front bumber johnpaulgolf 151 48,173 06-27-2008, 04:12 PM
  ZF 5-speed? blazinchuck 2 3,046 05-23-2008, 05:49 PM
Last Post: Bighorn
  I actuly got to work on my eb broncomatt 1 1,961 02-15-2008, 05:48 PM
Last Post: cuz1
  Tranny is in!!! NC-Fordguy 2 1,932 01-17-2008, 05:59 AM
