time for new axles!
Chuck, I can't believe you broke again. At least there is a warranty on the axles. Sorry I missed it.
you could give me your axles for christmas :lol:
i might could find a home for them under a b2
V-8 + manual tranny + 39 in tires + dana 44 + heavy right foot = broken parts
Perhaps some mogs or rockwells
Rockwells you'll loose the streetabilty
Mogs need some wheel base
I know of a set of rockwells that might still be for sale
1974, 331 stroker, Holley TA,Dana20 twin stick w/terra low gears, 456 axle gears, detroit in the rear, true track up front ,MSD ignition, 37x12.50 PJs, 9k warn-tabor
there you go chuck just get some rock and some 44s and you would be set
yeah, but I still like going to church w/the bronco :lol:
in waterboys moms voice "rockwells are from the devil"
Hope this isn't to good to be true, but I'm picking up a D60 out of an F-350 for $150 on Sunday. Now I'll need a matching front 60 so that I can grow.
http://forums.xjsrule.com/viewtopic.php?t=615
Failure is not an option!
fdezone Wrote:Hope this isn't to good to be true, but I'm picking up a D60 out of an F-350 for $150 on Sunday. Now I'll need a matching front 60 so that I can grow.
that aint fare, I want da 60 1st :lol:
Damn! I guess it was to good to be true. I was told it was a FF D60 out of a 79 F-350. There's no tag or anything on the axle itself. The web on the housing says C-30255, drums brakes, ONLY 16 spline axles, with an approximate 66.5" WMS to WMS. I assume it has 3.54s. Should I even bother with her? I'd want to upgrade to discs and 35-40 spline axles. What's a good source?
[Image: 2461074_251_full.jpg]
[Image: 2461074_250_full.jpg]
[Image: 2461074_249_full.jpg]
not sure, I found a FFD60 in the back of a ford van @ LKQ. I think they only charge $100 per rear axle. This weekend was 1/2 off too.
  It was the first time. . . nhopman 10 3,271 03-15-2016, 12:12 AM
  Well it is time to build one from scratch... shon 4 2,764 05-25-2015, 04:28 PM
  Narrowing axles from a 77 F150 4x4 Crawdad 5 2,164 05-27-2013, 09:13 PM
  New guy, 1st time Bronc hankster 17 3,310 11-28-2010, 03:19 PM
Last Post: hankster
  Chromoly axles badbronco 4 1,432 10-06-2009, 09:30 PM
  8.8 disc brake axles Bronconrocks 0 1,500 09-30-2009, 07:50 PM
Last Post: Bronconrocks
  first time in the mud with gumby! gumby93 8 2,752 07-22-2009, 08:57 AM
  to much time berg bronco 13 3,276 06-05-2009, 09:19 AM
  dana 44 stub axles yvon 10 3,253 06-24-2008, 09:37 AM
  time to push the limits blazinchuck 51 8,640 04-11-2008, 01:45 PM
