08-18-2009, 01:27 PM
I was wondering what the stock transmission and transfercase is for a 1992 FS Bronco with a 302 auto. Any help is appreciated.
Stock questions
08-18-2009, 09:07 PM
The only auto in '92 was the E4OD, and the transfer case should be bw1356.
[SIZE="4"]Founding member of the "cheap bastards 4x4 gang''[/SIZE] ![]()
08-18-2009, 09:32 PM
The E4OD is an electronically shifted tranny. I don't think they were produced until '95. The E4OD is a long tranny with a very long and deep pan. It was also known referred to as the 4R100.
![]() The AODE is an AOD with an electronically shifted OD. Looks very similar to the old AOD but with out the TV cable. It was later called the 4R70 or 4R70W. ![]() You can compare your transmission pan to this chart:
stock rear drums | scbronco | 11 | 3,085 |
03-06-2014, 08:09 PM Last Post: Bronco Biff |
Efi and stock fuel tank | snipes243 | 3 | 1,605 |
12-11-2012, 03:28 PM Last Post: Carolinaoffroad |
Got some EB questions for you guys. | dirty_sohc | 2 | 2,524 |
10-19-2012, 10:31 PM Last Post: dirty_sohc |
Hub/ Rotor questions | Crawdad | 2 | 2,087 |
01-31-2012, 09:46 PM Last Post: Crawdad |
Stock 66 interior rebuild thread | 66stocker | 37 | 12,525 |
04-03-2010, 11:07 AM Last Post: 66stocker |
Caster Questions | SC74 | 0 | 2,156 |
11-16-2008, 04:54 PM Last Post: SC74 |
A few questions | cuz1 | 29 | 10,442 |
04-02-2008, 10:55 PM Last Post: johnpaulgolf |
roll cage questions | johnpaulgolf | 21 | 6,659 |
12-09-2007, 06:37 AM Last Post: broncomania |
