RADIUS ARM BUSHINGS
IM GOING TO (ATMEPT TO) REPLACE MY RADIUS ARM BUSHINGS ON SATURDAY. FROM DOING REASEARCH ON IT PEOPLE SAY YOU HAVE TO DRILL OUT THE RIVETS FROM THE BRACKETS. THIS MAY SOUND STUPID BUT IF YOU ALREADY HAVE DROP BRACKETS INSTALLED DOES IT MEAN THAT THE RIVETS HAVE BEEN DRIILED OUT ? AND THE ONLY THING I NEED TO DO IS LOOSEN THE BRACKETS SO I CAN REMOVE THE OLD BUSHINGS? I JUST WANT TO MAKE SURE IM GOING ABOUT IT THE RIGHT WAY. MY WIFE ALREADY SAYS THAT THE BRONCO IS A MONEY PIT!
You should be able to loosen the drop brackets.But break the large radius arm nut loose first.It can be a bear to get free.
[Image: Outalne_017.gif]
will i be able to re use the nut?
I was able to use mine.
wish me me luck. this will be the first time i replace them!
  Pitman arm bushings? and a couple other suspension ?'s knoxville714 3 3,162 09-16-2016, 08:10 AM
Last Post: Deltabronco
  C- Wedge bushings snipes243 25 7,344 08-14-2015, 12:01 AM
  The 5/16" square hole in 76-77 radius arms Crawdad 3 3,150 01-14-2015, 12:38 AM
  Radius arm bushing cause of grinding/vibration sound? 1st Bronco 7 1,954 09-13-2013, 09:47 AM
  Extended Radius Arms cam coffee 19 3,671 11-27-2011, 09:58 AM
Last Post: Timstrk
  I need to know the Radius Arm width. 2000F150SAS 0 900 06-17-2009, 10:00 AM
Last Post: 2000F150SAS
  axle pivot bushings chulo2004 3 1,265 12-09-2008, 11:51 PM
  tracking bar and pitman arm seanrook 2 1,699 10-13-2008, 03:45 PM
Last Post: seanrook
