axle pivot bushings
is it hard to install new axle pivot bushings? i've been told that you need to disassemble the whole front suspension. then i heard that you don't need to. so which one is correct?
Although I haven't had to do it *yet*, it doesn't seem to be too bad if you have the "right" tools... Check out the how-to article on FSB... http://www.fullsizebronco.com/forum/show...hp?t=65881
Let me know how it goes and take some pics and post up your own how-to here and we'll sticky it!
Thanks,
JayT
i will try not to forget to take some pics. thanks for the info.
Not too bad at all, If you have a winch or a high lift its really easy. I prefer the rubber bushings with the pree load. Rubber is much quieter and seems to ride nicer.
  Pitman arm bushings? and a couple other suspension ?'s knoxville714 3 5,093 09-16-2016, 08:10 AM
Last Post: Deltabronco
  C- Wedge bushings snipes243 25 13,980 08-14-2015, 12:01 AM
  Axle Tube Vents Casey835 4 3,609 03-01-2013, 08:20 PM
Last Post: Casey835
  ***9" Axle Gurus...Ring gear dug into pilot housing!** chuzie 7 5,124 12-05-2012, 12:35 AM
  Axle / Gear gurus help!! SC74 4 4,157 03-28-2012, 08:52 AM
  F150 axle shaft tech blazinchuck 12 6,738 12-03-2011, 09:34 PM
  Stuck rear axle? (9") Action 6 4,587 06-24-2011, 09:42 PM
  rear axle shims? berg bronco 15 6,172 01-04-2011, 09:52 PM
  axle bluebooger 6 3,457 12-02-2010, 12:45 AM
  Axle Seal Leak.. Again! 73Bronc 13 7,135 10-15-2010, 01:50 PM
