The Love shack
#61
thanks guys. progress has been a little slow but thats gonna change come pay day!!
Eric. :rebel:
i fastened all the DP on today temporarly. checking fit etc. I pre drilled all the holes and ran 1" drywall screws in. this pre drills tha holes in the wood and when i pull it all off to seal it i can put caulking in the hole and under the screw. it all fit real well. i have to cut out for the furnace and trim one back piece but thats it. i also will eventually do the doors as marked and probably the pass thru doors.
[Image: repair2701.jpg]
[Image: repair2702.jpg]
[Image: repair2703.jpg]
[Image: repair2704.jpg]
[Image: repair2705.jpg]
[Image: repair2706.jpg]
[Image: repair2707.jpg]
[Image: repair2708.jpg]
[Image: repair2709.jpg]
[Image: repair2710.jpg]
[Image: repair2711.jpg]
[Image: repair2712.jpg]
[Image: repair2713.jpg]
[Image: repair2714.jpg]
[Image: repair2715.jpg]
[Image: repair2716.jpg]
[Image: repair2717.jpg]
Eric. :rebel:
[Image: th_MOV00697.jpg]
Eric. :rebel:
[Image: repair2801.jpg]
[Image: repair2802.jpg]
[Image: repair2803.jpg]
[Image: repair2804.jpg]
[Image: repair2805.jpg]
[Image: repair2806.jpg]
[Image: repair2807.jpg]
[Image: repair2808.jpg]
[Image: repair2809.jpg]
[Image: repair2810.jpg]
[Image: repair2811.jpg]
Eric. :rebel:
all its missin is some SPINNERS LOL BLING BLING
Lifes a garden dig it
bone collector Wrote:all its missin is some SPINNERS LOL BLING BLING
on order......NOT. lol
Eric. :rebel:
got a few things done. got slider mounted and operational and put the rest of the trim on it. i pulled out the awning to look at it and let it air out. i am missing a leg on it and one of the feet are broken. i got all the DP mounted on the drivers side. I sealed and mounted the electrical inlet flange and the phone and 2 cable hookups. i mounted the pass thru door and figured i would try my luck with running a bead around it. it came out good. I used to work with silicone a lot and was pretty good at running beads but you loose it if you dont do it. i also went ahead and sealed the top and 1st seam of the DP. came out really well im happy. i got one side of the slide done and am about to go eat then start the other side of the slide. i would like to get all the DP mounted and sealed today.
[Image: repair2901.jpg]
[Image: repair2902.jpg]
[Image: repair2903.jpg]
[Image: repair2904.jpg]
[Image: repair2905.jpg]
the piece at the top i am missing from the other side.
[Image: 6-3.jpg]
this is the foot of the awning. it is supposed to have a piece between the arrows thas broken
[Image: 7-3.jpg]
[Image: repair2909.jpg]
[Image: repair2910.jpg]
[Image: repair2911.jpg]
[Image: repair2912.jpg]
[Image: repair2913.jpg]
[Image: repair2914.jpg]
[Image: repair2915.jpg]
[Image: repair2916.jpg]
Eric. :rebel:
except the corner and bottom angle, the passenger wheel well trim, furnace install and clean up the outside is about done. all the DP is on and sealed
[Image: repair3001.jpg]
[Image: repair3002.jpg]
[Image: repair3003.jpg]
[Image: repair3004.jpg]
[Image: repair3005.jpg]
[Image: repair3006.jpg]
[Image: repair3007.jpg]
[Image: repair3008.jpg]
[Image: repair3009.jpg]
[Image: repair3010.jpg]
[Image: repair3011.jpg]
[Image: repair3012.jpg]
[Image: repair3013.jpg]
[Image: repair3014.jpg]
[Image: repair3015.jpg]
[Image: repair3016.jpg]
[Image: repair3017.jpg]
[Image: repair3018.jpg]
[Image: repair3019.jpg]
[Image: repair3020.jpg]
[Image: repair3021.jpg]
[Image: repair3022.jpg]
Eric. :rebel:
Man you do some jam up work. Keep up the good work.
thank you sir. i got a few hrs to tighten it up on the outside. install furnace, remove stickers from storage doors and slide frame. remount awning feet. I have to get one more sheet of DP for the front also. i need to start cleaning up and packing. im moving back to Mcbee by may 1
Eric. :rebel:
